JuicyGNJ
Results 1 to 20 of 20
    ruairi83's Avatar
    Dec 2007
    486
    Post Thanks / Like
    Audi A3 1.9TDIe 2009 Fuel Economy prob
    Im getting very very poor fuel economy.
    Have a Audi A3 1.9TDIe 2009. Car is on standard 16" wheels and good michellin tyres with good pressure.
    Car has 109k miles, full history, new air filter, fuel filter this week and skirt of millars fuel cleaner. going to change pollen and oil filter this wend.
    This is suppose to be the eco model that gets 62mpg but im getting no where near this.
    for just under half a tank i got 219miles. Ive been driving the car properly and changing gears when trip computer tell me to but this is a joke.
    Could it just be like this as it needs a service (oil and Filter) be the prob?
    There is also a musty smell in car, dont think the air con has been regassed before. ive been turning it off completely so it doesnt use the fuel either.
    anyone any ideas why it could be eatting the fuel?
    ruairi83's Avatar
    Dec 2007
    486
    Post Thanks / Like
    anyone any ideas?
    ruairi83's Avatar
    Dec 2007
    486
    Post Thanks / Like
    no one else had this?>>>????
    Scotland
    58
    Post Thanks / Like
    I've had this problem on my 2010 1.6TDI which is supposed to return easy 60+. Despite regular battles with Audi UK nothing could be resolved. I've been lucky to get 48mpg!!
    Does your car have a DPF (Diesel Particulate Filter)? If so get that checked. Other than that I would certainly replace Oil, check brakes are working properly and not dragging. A brake piston may be seized. I wouldn't go with the DIS. I would fill tank full and check after refill for 'actual' MPG
    ruairi83's Avatar
    Dec 2007
    486
    Post Thanks / Like
    doesnt have a dpf mate. ive fully service it and checked brakes and all ok there.
    im regreting buy this now. thinking i might sell on ....
    Jan 2012
    65
    Post Thanks / Like
    My 1.9 is being very hit and miss. 45mpg one tank then 60mpg the next and I do exactly the same driving.
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,201
    Post Thanks / Like
    Quote Originally Posted by ruairi83 View Post
    What sort of driving are you doing? We have a 2010 170 TDi Common Rail s-tronic A3 and get 550 - 600 miles to a full tank and 55mpg on a mixed driving run. Even around town we get 45mpg...
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    Nov 2008
    182
    Post Thanks / Like
    I have the Sport version of your car and get 650+ to a tank - daily mostly windy Yorkshire roads with a bit of A1 thrown into the mix. DIS generally averages 58+ MPG. Swapping for a 1.6TDI common rail later this year - should hopefully get better still but who knows?
    Work: A3 Sportback Sport 1.9TDI Home: A4 Avant 2.0 TDI Quattro S-Line
    Nov 2008
    182
    Post Thanks / Like
    Also, although not widely publicised, I think the 1.9TDIe does have a DPF - Golf bluemotions with the same engine and from the same time do and these do too (maybe)
    Jan 2012
    65
    Post Thanks / Like
    I don't see a dpf light when I turn the ignition on on my tdie a3
    Cardiff, United Kingdom
    363
    Post Thanks / Like
    Ive got a 1.9 TD 2008 model and Im sure I have a DPF, I think it was chnged on my last service.
    ruairi83's Avatar
    Dec 2007
    486
    Post Thanks / Like
    i got a local tuner to check and i defo dont have a dpf and he checked through car and it seems fine but mpg is awful. going contact audi monday with chasis and check about dpf for sure.
    Nov 2011
    South Yorkshire
    134
    Post Thanks / Like
    I also have a similar problem but mine is the 2.0 tdi sport 140bhp.
    I bought mine 2nd hand 6 months ago around 110k on clock. I had full service done to it. Still was getting low mpg. I thought this maybe due to the fact I let the diesel go low as when you get the warning on DIS. So I have been been popping in £40 of diesel just before the needle hits the 1st red line.
    At the most I have been getting around 150 miles local driving plus about 50 miles motorway driving before it goes back to the red line and I have been driving around like a girl.
    I dont calculate using DIS, however DIS shows miles dropping like crazy. I might just drive to bottom of the road and it drops by around 10 miles on DIS lol
    Nov 2011
    South Yorkshire
    134
    Post Thanks / Like
    Will my car have DPF, also will MPG be affected by something such as not having under tray on?
    Just found out mine is missing
    Scotland
    58
    Post Thanks / Like
    What the missing undertray will do will be absolute minimal I would imagine. Phil_W I have the 1.6TDI common rail engine and with regards to consumption and performance...beware!! It is sooo underpowered. When in low revs it struggles to get up slight hills, you have to drop a gear or two and build up revs therefore using a helluva lot of fuel. In high revs it uses a helluva lot of fuel anyway. I know alot of people now with this engine and are very dissapointed in it. I also know the 2.0Tdi can be far more economical, smoother and obviously more power. In my opinion stay away from 1.6tdi.
    With regards to getting a 'full service' done ask if they have changed the filters. I've had two 'Audi' full services and on both none of the filters had been changed. I ended up doing it myself
    Nov 2011
    South Yorkshire
    134
    Post Thanks / Like
    I didn't get the service done by Audi
    Nov 2008
    182
    Post Thanks / Like
    JCMCN - noted on the 1.6TDI but although I'd be no worse off with a 2.0TDI at first (company car tax) - in years 2 and 3 the tax goalposts move to make you considerably worse off if you have a 2.0TDI over the 1.6TDI. Can't win really!
    Nov 2008
    182
    Post Thanks / Like
    Just for reference - last week I got 350miles on the halfway mark on the gauge and this week more like 380.
    Nov 2008
    182
    Post Thanks / Like
    JCMCN - Have been pondering over this now for a while and I think I'll take a punt at a Black Edition 2.0TDI rather than s-line 1.6. The revs/economy thing makes sense. Think I'll borrow a 2.0TDI from the dealer and take a couple of days of real world commute for an assessment...
    Scotland
    58
    Post Thanks / Like
    Enjoy Will be keen to hear how you get on
  1. Audi A3 1.9TDIe 2009 Headlights and DRL's
    By ruairi83 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th January 2012, 10:58
  2. S3 Fuel economy
    By brough74 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd August 2011, 22:36
  3. Audi a4 2.0 tdi VERY poor fuel economy (20mpg) and engine starting problems.
    By audi 88 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 26th July 2011, 17:00
  4. Audi a4 2.0 tdi VERY poor fuel economy and engine starting problems.
    By audi 88 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th July 2011, 10:54
  5. Fuel Economy on an Audi 80 1.6
    By M Dogg in forum Classic Audi Forum
    Last Post: 15th May 2008, 17:31
