AWEsome GTIRevo Technik
Results 1 to 16 of 16
    Dec 2011
    11
    Post Thanks / Like
    Help!!!!Audi a3 esp & steering light
    Hi, Bought an Audi a3 2.0 tdi 2004 about a month ago. Been driving like a dream, did 300 miles to manchester on tuesday and no problems at all.
    However last night I was driving home from work and all of a sudden the esp light and steering light came on, and cant get rid. The steering now doesnt auto centre and it seems sluggish?!
    Any suggestions??
    Steven
    Fossie
    2,746
    Post Thanks / Like
    Get it scanned with VCDS to identify the problem. Check in the VCDS User section of this forum to see if anyone lives near you who could scan it for you.
    On the other hand, providing you bought from a dealer then take it back and get them to fix it.
    Dannykn9's Avatar
    May 2011
    North London
    544
    Post Thanks / Like
    Get VCDS and read faults. Also try to clear them, if all fails then a trip to the garage is needed.
    Did you buy the car from a dealer or car place, if so, take it straight back and get them to deal with it.
    ​"Cruise Installer"
    Dannykn9's Avatar
    May 2011
    North London
    544
    Post Thanks / Like
    Sorry Mike, wrote my post as you justed posted yours. Haha, sorry mate.
    ​"Cruise Installer"
  6. Thanks mike foster thanked for this post
  7. #5
    Fossie
    2,746
    Post Thanks / Like
    Quote Originally Posted by Dannykn9 View Post
    Snap !!!!!
  8. Likes Dannykn9 liked this post
  9. #6
    Dec 2011
    11
    Post Thanks / Like
    It was a private sale,but i did have a full service done on saturday and the mechanic plug up diagnostics for free and there was only 1 fault for a glow plug.
    Hes coming back tomorrow to dianose again.
    Have any of your heard of these problems?!
  10. #7
    Fossie
    2,746
    Post Thanks / Like
    There will be more faults indicated this time ! Hopefully your mechanic has VCDS because not all diagnostic readers identify VAG problems.
    If you have disconnected the battery at all you may need to have to reset the basic settings but VCDS will tell you.
  11. #8
    Lewis583's Avatar
    Mar 2010
    276
    Post Thanks / Like
    If he only told you about the glow plug error odds are either, he has a turd scan tool or he didn't go into ABS/ESP and Steering ECU to read the codes.
    2006 A3 2.0T Quattro S-line
    1990 Golf GTi
    Full VCDS
    ** Breaking - 8L 1997 Audi A3 1.8T. **
  12. #9
    ElliottB's Avatar
    Audi A3
    Nov 2011
    East Yorkshire
    107
    Post Thanks / Like
    I have the same fault on mine bud.
    Im waiting for mine to be taken in and fixed. Apprently its the 'steering angle sensor'
    Audi A3 8P 2.0 TDi - Full Leather Interior
  13. #10
    BlueSpark's Avatar
    Aug 2010
    South London
    280
    Post Thanks / Like
    Agree with above. Have you disconnected/reconnected the battery, if so you will need to reset it. Also you need full VCDs to diagnose all faults.
    Ron
    Audi A3 8P2 2.0Tfsi S-Line Special Edition
    3dr Mauritius Blue || Full Leather|| BOSE || MFSW || Auto Lights/Wipers || Auto Dim Rearview Mirror || Heated Mirrors
    Mods: S3 Aluminium Pedals || S3 Vents || 2010 RNSE || OEM Bluetooth || Dension Gateway 100 || MY09 Rear Lights || Single Xenon Headlights
  14. #11
    Dec 2011
    11
    Post Thanks / Like
    I read on net yday that disconnecting battery might reset warning lights, So I disconnected battery. so how do i actually reset it?is it safe to drive do you think?only difference is steering doesnt auto correct
  15. #12
    ElliottB's Avatar
    Audi A3
    Nov 2011
    East Yorkshire
    107
    Post Thanks / Like
    It is still safe to drive as i am having the same issue on my car.
    You can only reset it using VCDS
  16. #13
    Fossie
    2,746
    Post Thanks / Like
    Quote Originally Posted by l1ons81 View Post
    Hang on a minute - Have you moved the car since you disconnected the battery ? What you need to do is drive forwards in a straight line for about ten metres; turn the wheel full lock to the left, hold it there for a few seconds and back to centre; full lock to the right, hold and back to centre and drive backwards in a straight line to where you started.
    This should reset the steering sensor. If I remember correctly you should then be able to switch off the engine, start again and it should have sorted itself out. However, you may need VCDS to clear the fault codes first.
  17. Thanks FranA3 thanked for this post
  18. #14
    Dec 2011
    11
    Post Thanks / Like
    I have moved the car,but it was to drive to work this morning,I will try that method tonight and hopefully it works.
    alot of other bits of advice suggest low battery?is that common?
    cheers for advice mike
  19. #15
    Dec 2011
    11
    Post Thanks / Like
    right,diagnostics came back with a steering sensor fault and the battery was running off 11volts and was nearly dead, So ive got a new battery and on the look out for steering sensor, does any1 know the part number?
    my car is a 2004 audi a3 2.0tdi sport.
  20. #16
    Fossie
    2,746
    Post Thanks / Like
    It is unlikely that there is anything wrong with the sensor. It just needs re-setting. Find someone near you with VCDS who can help you.
    Otherwise please post the actual diagnostic fault code and description.
  1. Guide: ESP Light On- Glow-Plug/Engine Light Flashing - Cause & Fix Inside!
    By Yoof in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th January 2012, 11:07
  2. ESP & ABS light
    By landopanda in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2011, 18:32
  3. Battery died and now have power steering light and esp light on ?
    By bradus in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th December 2010, 14:46
  4. power steering & esp light came on after i washed car???
    By trailboss in forum General Technical / How To
    Last Post: 20th June 2010, 21:05
  5. ESP & ABS light always on help ?
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2010, 09:03
