Speed warning
Helifella
Co-Driver ~ Hattie
Knaresborough
Anyone know why there is a small "2" next to the amber caption when I exceed the set speed in DIS?
Can you set 2 speed warnings????
i also had this today but mine said 1 by it i went into the menu and its turned off and set to 155. so i dont know why , i was altering the clock at the time. but that may consistence. i was doing just under 30mph at the time.
thanks
I had this today
I think if your trying to adjust the clock whilst driving, and pull the adjuster out it sets the speed warning for the speed when your adjusting it.
Mine's set to 88mph so I know I'm about to go back to the future
Reactions: wuta3, RPB and Tonka Toy
Mine's set also to 88mph, hear it more than I should :whistle2:
Reactions: Tonka Toy
155mph......I wish ;-)
80mph. That way I should get off with a warning if I get caught. Not that I go over 70mph ;-)
Reactions: Andy Crooks
i only put it to 155 not because i do that, because i tried to put greater disance from the 30 mph it came on at , i dont know is was trying everything.
Ditto! Should only be the hairdryer at worst if caught by PC Plod and not 3pts.
I'm told they allow speed limit + 10% + 2mph before nicking you so 80mph on a motorway is as far as you should safely push it!! :angrymod:
well its insured with Adrian "Flux", is that close enough??
797
734
