KowalskiAdrian S Flux
    Jan 2012
    Post Thanks / Like
    Dual Mass Flywheel Noise?
    Hi,
    I have a 2011 2.0T BE SB with manual gearbox which now has 1500 miles on the clock.
    I've noticed the car makes an annoying (maybe I'm being too picky?) vibrating/grumbling noise when engaging the clutch from standstill in 1st gear, most noticeable on hill start. My supplying dealer (150 miles away) says it could be due to the dual mass flywheel on these cars and could be perfectly normal, but can't tell without hearing the car.
    Is it something that I should just be tolerating and is normal with this type of car, or should I be taking the car back under warranty? I've already been to my local Audi dealer who told me the noise was the brakes (as it can be demonstrated most effectively stationary with the handbrake on and the clutch just biting) and also that the 2.0T was just a noisy engine.
    Appreciate any advice from other 2.0T manual A3 owners.
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    134
    Post Thanks / Like
    If it was me i'd get it checked out. Depends if you have the time to trek the 300 miles round trip or not I guess
    warren_S3's Avatar
    Oct 2007
    Undetermined
    4,404
    Post Thanks / Like
    Dealer will tell you anything to save them warranty work which isn't well paid for them. If it breaks they'll feel obliged to fix it.
    I'd get a quick independent check to confirm as Audi are unlikely to give you are accurate diagnosis.
  1. Dual Mass Flywheel
    By sidibear in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th October 2011, 00:40
  2. Dual mass flywheel
    By cee-gee in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th May 2011, 19:03
  3. Dual Mass Flywheel
    By RJB1875 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th June 2010, 21:24
  4. Dual Mass Flywheel
    By Geraldy212 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th December 2008, 15:38
  5. A4 Flywheel...dual mass?
    By robw963 in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th December 2004, 22:24
