W8 PerformanceDTUK
Results 1 to 10 of 10
    Dec 2011
    Manchester
    67
    Post Thanks / Like
    Bonnet doesn't seem to fit correctly aligned........??
    Been thinking about having my grille sprayed black, looked back at my photographs of it and checked it out last night while fitting sidelights and the bonnet genuinely doesn't seem to fit right down to perfect alignment. I've looked at images of AidenUK's SB same as mine and his seems to be flush, although the images weren't shot from the angle mine are. There does seem to be a lip though that doesn't feel quite right. Could anyone shed any light on this? Hoping this ain't nothing major(fingers crossed).
    Davo..
    BBlackburn's Avatar
    Jul 2011
    Epsom, surrey
    355
    Post Thanks / Like
    When I changed my bonnet to accommodate my full grille conversion I had this same problem and my friend who helped me fit the bonnet also mechanic and body repairer just opened the bonnet held it up and bent it either way and it made massive crack! But aligned it up perfectly then he said to me that it wouldn't have made that noise if it was aligned right. So you could try that but I'd recommend not to hard incase doesn't go as smoothly.
    SPEC: ebony pearl black ~ auto lights ~ auto wipers ~ half leather/suede interior ~ armrest ~ anti dazzle rear mirrior ~ coming home/ leaving home function.
    MODS: flat bottom steering wheel ~ bluetooth ~ cruise control ~ rns-e ~ MY09 rear lights ~ s3 pedals ~ s3 air vents ~ LED interior light pack ~ facelift buttons ~ dension ~ SDS ~ Aliminium inlays ~ full grille conversion.
    FUTURE MODS: lower ~ black edition rear ~ s-line/facelift front ~ black headlining ~ BBS CH-R or Speedlines.
    Dec 2011
    Manchester
    67
    Post Thanks / Like
    Quote Originally Posted by BBlackburn View Post
    Wow, really. That is interesting. I'm hopefully getting down to see user N8 soon so might see if he can help me out with that or has any recommendation. When you say "bent it either way" down you mean directly left and right from looking at it face on from the front??
    Cheers for the reply!!
    BBlackburn's Avatar
    Jul 2011
    Epsom, surrey
    355
    Post Thanks / Like
    Quote Originally Posted by TheMacMagician View Post
    Yeah sorry didn't really describe that very well he just held both corners at the top and twisted it either way.
    monster_munch's Avatar
    Dec 2011
    123
    Post Thanks / Like
    I dont mean to scaremonger or anything, but misaligned panels, especially at the front of the car, is a sign of crash damage. When Im looking at a new car I always check the gaps between the bonnet and wings are equal and that the bonnet and bumper etc all sit flush.
    Has it been crashed?
    Dec 2011
    Manchester
    67
    Post Thanks / Like
    Quote Originally Posted by monster_munch View Post
    Hi pal. I was kinda thinking that, but I'm not sure whether "misalignment" is maybe the wrong description on my part. I can totally see what you would mean, but everything is perfect, just that the bonnet doesn't seem to sit down maybe by maybe 6 - 8mm when it meets the grille and headlights. Alignment/spacing between wings is perfectly equal either side so it is literally as if that bonnet needs to dip by that extra 6 - 8mm. If it was crashed, its been incredibly well concealed I'd say, as everything is pretty immaculate barring a few stone chips here and there on the grille, bumper and bonnet.
    You've confimed for me that I should defo have it looked at anyhow.
    DAvo.........
    The Engineer's Avatar
    Apr 2011
    Mid / Northwest
    252
    Post Thanks / Like
    Mine did this whe I removed the bumper to wrap my grill.
    It ended up being the bumper that needed lining up
    Dec 2011
    Manchester
    67
    Post Thanks / Like
    Quote Originally Posted by The Engineer View Post
    That's an interesting answer as I think the bumper has a large chip at the bottom that has been touched up, maybe they took the bumper off to make it easier to finish and didn't refit perfect. How did they correct it for you??
    warren_S3's Avatar
    Oct 2007
    Undetermined
    4,404
    Post Thanks / Like
    My S3 8P2 bonnet looked misaligned from factory, so much so we queried it with the dealer who said they all seemed to look a bit off. Just accepted it, but didn't look that different to yours.
    Dec 2011
    Manchester
    67
    Post Thanks / Like
    Quote Originally Posted by warren_S3 View Post
    Oh right. It does look perfect aside from needing to sit a fraction deeper when the front end above the lights and grille are concerned.
    Whe I get it down to N8's place I'll see whether they think it needs checking. Cheers for the replies fellas.
  1. Can a A3 bonnet fit on a '98 A4 Audi?
    By djspider88 in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd June 2010, 18:34
  2. will an 09 bonnet fit my car?
    By DOLPHIN DIESEL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd April 2010, 07:54
  3. Bonnet prices to fit a single grille..
    By AidenUK in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st April 2010, 21:42
  4. Q7 Not Starting Correctly
    By d8vil in forum Q3, Q5 & Q7 Forum
    Last Post: 12th October 2009, 19:07
  5. How does one align the lights correctly?
    By necroeire in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th June 2006, 01:07
