Hi,
Ive fitted a new front wiper motor to a 2004 8p. No hids or automatic wipers. But it wont work. Ive tried to figure out how to code the motor, but cant find it on the long coding helper. Any ideas? cheers
Hi,
I didn't think it needed coding.
You did make sure the bonnet was closed properly before you tried it didn't you because it won't work otherwise.
Audi dealer said it may need coding. got a fault code on the central electrics- 02071, something about no signal
never had to code a wiper motor
are you sure its the motor at fault ?
could be the wiper arm a relay dodgey wire
02071 - Local Databus 02071 - Local Databus: No Signal/Communication
Possible SymptomsPossible Causes
- Control Modules connected to Local Databus not functioning
Possible Solutions
- Wiring/Connectors from/to Control Modules in Local Databus faulty
- Control Module in Local Databus faulty
- Check/Repair Wiring/Connectors from/to Control Modules in Local Databus
- Check/Replace Control Module in Local Databus
thanks got the symptoms/causes/soloutions from rosstech. im now onto checking the motor/linkage/connections. Funny thing is the washers are working fine.
the wipers can be coded under the central electrics module (09) and then click on to coding. before clicking on long coding helper select the front wiper from the drop down at the top and then click onto the coding helper. though i cannot see that being the problem in this case
Ash
A3 Sportback 2.0TDI
Dark Headlining, Bose, Alcantara Leather, Lights Pack
MODS:
Bi-Xenons, Auto lights, S-Line Bodykit, FK S3 Grill, TTRS FBMFSW & Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims, Exclusive LED Kit
Items for Sale
My Blog & Build Thread: Ash.Net
BBM: 2888DD52
