AWEsome GTIJBS
Results 1 to 14 of 14
    Nov 2011
    South Yorkshire
    134
    Post Thanks / Like
    Rear Washer Pipes
    Need some help guys
    My rear washer isnt working, I have removed the boot trim and tested. No water is reaching the pipe.
    Will the pipe be disconnected from the resevoir if so how can I locate it?
    Off work tommorow so really could do with sorting this out
    Nov 2011
    South Yorkshire
    134
    Post Thanks / Like
    Any suggestions guys?
    jamessg1962's Avatar
    Jan 2006
    Newcastle
    108
    Post Thanks / Like
    Can you here the pump running ? If not check to see fuse OK for washer pump. If you can here pump running may be case of pipe popped of possibly due to freezing .
    Jan 2006
    Newcastle
    108
    Post Thanks / Like
    I think the fuse is No 42 located right hand side of dash. Just pop cover off ,its a15A fuse blue in colour
    Nov 2011
    South Yorkshire
    134
    Post Thanks / Like
    Yes pump is running. I have removed the pipe from the motor and no water is reaching it.
    Where can I check to see if pipe has popped off?
    Nov 2011
    South Yorkshire
    134
    Post Thanks / Like
    Does the pipe need to be connected to the wiper motor in the boot for the pump to work
    Is the pump located near the engine?
    Jan 2006
    Newcastle
    108
    Post Thanks / Like
    Unless you have been doing something that might have nipped/squashed pipe somehow i don't think that is the problem.
    The pump i think is located near to washer tank You may be able to get to it from the wheel arch but not sure about this.Can you see any water leaks around engine bay when operating washer pump.The pipe may have popped off from pump end not wiper end.
    Jan 2006
    Newcastle
    108
    Post Thanks / Like
    Have a look here ,it may be of help .
    Rear window washer not working?
    Nov 2011
    South Yorkshire
    134
    Post Thanks / Like
    would the pipes for the 8p be in the same location as the 8L?
    Nov 2011
    South Yorkshire
    134
    Post Thanks / Like
    Jan 2006
    Newcastle
    108
    Post Thanks / Like
    Not quite sure if its in same location on 8P as 8L. so don't go pulling bits out yet.Sure somebody will point you in right direction.
    Nov 2011
    South Yorkshire
    134
    Post Thanks / Like
    Right I think I know where the leak.You can see in the picture where the leak is
    Uploaded with ImageShack.us
    How to take this part off. I tried pulling it however didnt use too much power as I dont want to break anything
    Nov 2011
    South Yorkshire
    134
    Post Thanks / Like
    Any ideas how this comes off?
    Nov 2011
    South Yorkshire
    134
    Post Thanks / Like
    Bump This is on the drivers side.
    Also does anyone know what route the pipes take from the washer tank?
  1. washer pipes
    By Mike B in forum General Automotive Chat
    Last Post: 3rd June 2011, 20:16
  2. rear washer
    By pagey in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th July 2010, 21:29
  3. 8P - rear washer
    By sprout99 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th December 2008, 20:38
  4. rear washer?
    By nezzi in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2007, 12:48
  5. S3 Rear Washer.
    By joe6886 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2007, 16:54
