Just bought a set of 9j Audi tt wheels, unfortunately two tyres have gone though. Theyre currently wrapped in 245 40 18's but I'm just wondering if I can replace the two shot ones with 235 40 18's...
Would this be a good idea?
Thanks in advance!
Thanks in advance!
Good luck getting them to fit on an A3/S3!
Current rides - S3 8P3, MK2 Golf GTi 16v & MK4 Golf GTi daily.
Old rides -
A3 2.0T S-Line
A3 TDi Quattro S-Line
S3 8L (Revo)
Impreza STi Blob
306 Rallye
Leon Cupra R (Revo)
S3 8L (Revo)
Impreza T2000 Classic
306 Rallye
MK3 Golf GTi 8v
........plus a few more in between.
Tyres or the fact the wheels are 9j?
Wheels. You would probably need at least 12mm spacers leaving the wheels sticking out about 30mm more than a standard S3/S-Line wheel.
Old rides -
A3 2.0T S-Line
S3 8L (Revo)
Impreza STi Blob
306 Rallye
Leon Cupra R (Revo)
S3 8L (Revo)
306 Rallye
MK3 Golf GTi 8v
Whats the offset of the wheels? I have 19 x 9J ET42 on the rear of my A3 and they are grand.
You'd probably be best looking for 225/40/18 to give a bit more clearance around the arch
For Sale -
A3 rear wiper motor and arm
A3 air vents
56plate A3 S-Line full speaker system including amp
They're ET51 chap, Ive heard that the fronts will be a bit tricky though.. would 225 40 18 be slightly stretched? Also, because two tyres are basically new, would I be able to have say 245 on the back and 225 on the front? Or would this be not advised
Tyres need to be 225/40 ideally 245 will be too big and alter the speedo etc
Car-less at the moment
I'd say you'd need a 8mm spacer to get them fitted on the front. 225 will have a slight stretch on a 9J rim, it should look good though.
I ran 225s on the front and 235s on the rear of my car without any issues. As long as the tyre profile is the same on all four wheels and the tyre width is the same on each axle. Is your car quattro? Some argue that all four tyres should be the same for quattro cars, I don't think different tyre widths will pose an issue though.
PM N8 on here, he's the local wheel guru and should be able to tell you if the wheels will fit or not!
For Sale -
A3 air vents
Ok thanks! My mates got some 235 40 18 tyres would these be sufficient or would I HAVE to have 225's to actually make it work??
