Hi,
Took car for a routine MOT today to Audi.
While there the following problems were found.
ABS Pump/Sensor kanckered = £588.38 to fix
Knew the fault was there as the dash light came on. Spoke to Audi UK today to see if they can help me out. Fromt what I've read, not just on here there is a manjor "known" issue with them.
Oil Leak in or around manifold = £600.34 to fix
Full service was only carried out in November, don't understand how all of a sudden I can develop an oil leak "in the manifold" ???
Without any sign of leakage or problems... apparently a valve had collapsed!?!
Cam Belt change = £342.07 to fix.
Fair enough, needs changing after 5 years. Although a kick in the teeth since I've only had it 2 but hey ho, ntohing I can do about that.
LinkBack URL
About LinkBacks
