DNA TuningRevo Technik
Results 1 to 8 of 8
Thread: Decat?
    Jan 2011
    35
    Post Thanks / Like
    Decat?
    Hi!
    Am i going to see any improvement in lag if I take my cat out, gut it, and fit it back in? This is prior to the stage 1 remap.
    Also will it pass MOT with no cat?
    Also, when starting up from cold is it usual to get a ton of white smoke (i think its just condensation, it doesnt smell of oil...) ?
    Many thanks!
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,633
    Post Thanks / Like
    Quote Originally Posted by thesmileyone View Post
    Hi!
    Yes
    NO!
    Yes.
    bez101's Avatar
    Jul 2008
    3,425
    Post Thanks / Like
    dont gut it
    it will sound crap get a decat
    jungleman's Avatar
    Mar 2010
    SW London
    2,039
    Post Thanks / Like
    Hi!
    Many thanks!
    ok here are a few things, gutting is bad as you will still lag as there are a lot of restrictions on the down pipe, so you really need a properly designed system to funnel the exhaust gases out as the stripped cat section will prob cause a load of turbulence and grief, also doing this without a stage 2 map will result in you always having the engine management light on.
    when it comes to the MOT on visual inspection, with a gutted cat section they will in theory pass it, but without mapping to correct the EML and fuelling it may very well fail on emissions
    you won't get any white smoke, but you will get a wiff of petrol for the first couple of minutes after a cold start
    hope that helps
    Factory: Phantom Black S3, BOSE, RNS-E, Adaptive Lights, Interior Lights, Auto Lights
    Added: Evolve Stage 2 Map, Evoms CAI, Milltek TBE Non-res With Special Tips Now At 360bhp & 385lb/ft, VWR 4 pots, H&R Springs, H&R Spacers, Sachs Clutch, '09 Rear Clusters, Pressed Metal Plates, TT Air Vents
    To Do list: Now that would be telling
    PM me for Weitec & KW coilovers
    bez101's Avatar
    Jul 2008
    3,425
    Post Thanks / Like
    you can get a spacer to stop the light comeing on
    depending on who you use for the map some write it out some dont on stage 1
    jungleman's Avatar
    Mar 2010
    SW London
    2,039
    Post Thanks / Like
    I've heard of the spacer, not seen one before, always worth a try
    true, though you would have to specify the lambda defeat to the tuner though as that not a standard stage 1 spec
    what car you mapping anyway?
    Jan 2011
    35
    Post Thanks / Like
    tdi 140 dsg
    Is the miltek large bore downpipe a decat?
    2004 Audi A3 2.0 Tdi Sport - Lava Grey.
    HIGGINS's Avatar
    Mar 2010
    507
    Post Thanks / Like
    Miltek downpipe £180
    Get a remap to support it
    Selling MY11 rear lights, message me for a price
  1. decat help please!!
    By frank s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2011, 13:45
  2. Anyone want a decat?
    By B5NUT in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st June 2010, 13:11
  3. S3 decat
    By vetch in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2009, 12:39
  4. 1.8T Decat.
    By RyanGolfGTTDi in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2009, 22:05
  5. Decat
    By Timmc in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th June 2008, 14:56
