AMD TechnikGNJ
Results 1 to 8 of 8
    munchkincoupe's Avatar
    Aug 2010
    595
    Post Thanks / Like
    Number plate allen key rounded off?!?
    I bought some of these from ebay to replace the rounded off Audi screws eBay - The UK's Online Marketplacegone to replace a bulb today and one of the bolt heads has rounded off
    How do I get a rounded allen key bolt out please????
    Sheikh's Avatar
    Aug 2011
    Surrey
    606
    Post Thanks / Like
    I got it out by, grabbing the head with some pliers (the ones that lock in place) and then just twisting them out! Was a total pain though, good luck!
    2004 Audi A3 2.0 TDi Sport - Moro Blau Pearl - Half Leather Interior - Bose - Remapped - Lowered 30mm.
    Wish list: RNS-E (led), FBMFSW, Tints.
    Private plate for sale: Y 7RYY
    East Sussex
    551
    Post Thanks / Like
    Well I would not use the one you bought either, I would acquire stainless steel ones.
    I would try WD 40 to loosen the bolt, and try again.
    It is quite hard to remove a bold with a rounded head, especially if you cannot get grips onto the head. I would drill it out with a small drill being careful to make sure it is in the centre and not to drill into the hole thread. By rights you need a screw extractor that is like a tap with a reverse thread on it that tightens into the old bolt and winds it out.
    I must stress it is quite a skilled job with small bolts.
    Good luck with it
    mjr901's Avatar
    Speed Freak
    Nov 2011
    Worcestershire
    609
    Post Thanks / Like
    try a torx head that's slightly to big and a hammer then untighten. tends to work when I balls screw heads up
    Jan 2012
    Post Thanks / Like
    hi did you get the bolt out with the locking plies if yes fine,if no try grinding a slot in the head of the screw with a bradall (very small grinder )this will let you use a screw driver,
    xanderxxx's Avatar
    Jul 2011
    Brizzol
    86
    Post Thanks / Like
    Try a small anti-clockwise drill bit (stud removal kit type) into the head generally this will bring it out if not, then, the hole you made (small) put a stud extractor in out itll come. not sure where you are but if near Brizzol i have the kit to do it with if you can't get it out
    Aug 2010
    595
    Post Thanks / Like
    Thanks for the advice fellas
    Would these be a better idea then M3 A4 Stainless Steel Button Head Socket Screws MARINE GRADE Small Quantities | eBay
    if so I will order them in 12mm and have another go at removal on wednesday. Will probably go with the slot and screwdriver method as I'm quite handy with my dremel disc cutters
    Mar 2011
    68
    Post Thanks / Like
    Quote Originally Posted by munchkincoupe View Post
    I am selling these a bit cheaper see here:
    http://www.audi-sport.net/vb/sale-wa...ml#post1478533
  1. Dropped an allen key in engine bay
    By jackj in forum General Automotive Chat
    Last Post: 2nd May 2011, 19:49
  2. Dropped an allen key in engine bay
    By jackj in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd May 2011, 14:34
  3. What size allen key???
    By crazychris in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th February 2011, 19:38
  4. Weitec allen key
    By Scott in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th January 2010, 23:16
  5. help. allen key dropped down front of s3 dash!
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2006, 22:48
