JBSJuicy
    Sep 2011
    Newcastle Upon Tyne
    13
    Post Thanks / Like
    A3 2.0Tdi Quattro lost all drive on motorway?
    Hi lads,
    i was wondering if you could help me out with another problem i have ?
    Earlier tonight, i was pulling up the slip road in third to join the motorway, put it in forth, got about 50yrds down the motorway and lost all drive, engine just revved? so i had to roll to a stop on the hard shoulder.
    The car still idles no problem but you can put it in any gear quite easily without dipping the clutch with no affect to the car, still idles as it should.
    Within minutes the police where behind me saying i had 20 minutes to move it or they will recover it for a fee of £150 (nice of them), i got my mate to pick me up so i could collect my van to tow it back home quickly as possible
    Now its home again, i thought i'd post on here to see if any one has ideas of what the problem could be?
    many thanks in advance..
    Andrew
    Baza1819's Avatar
    Tdiiiiiiiii 170 quattro.......
    Jan 2012
    Sunderland
    107
    Post Thanks / Like
    Clutch fooked I thinks..........
    ooooooosssshhhhhhhhhh
    TDIiiiiiiiiiiiiiiiiiiiiii 170............
    Full S-line, S-line half Leather heated seats, Bose sounds, fold in heated mirrors, tyre pressure monitors, Charcoal roof linning, Mfsw,phone prep, 18" Speedlines, Dual climate.
    chris1988brown's Avatar
    middlesbrough
    497
    Post Thanks / Like
    definatly sounds like the clutch has done mate
    2007 a3 s-line 170 DSG
    MODS DONE: FULL COLOUR CHANGE SOLOAR ORANGE WITH GLOSS BLACK DETAIL - S3 REAR DIFFUSOR - S3 SIDE SKIRTS AND SCUFF PLATES - AP COILOVERS - BBS CH 18'S- TINTS - MILLTEK TURBO BACK EXHAUST - GREEN COTTON FILLTER - HYBRID TURBO - RS TUNING REMAP - S3 BRAKE CONVERSION WITH GROOVED DISCS - CARBON ROOF - B PILLARS & MIRROR BACKS - 2011 REAR LIGHTS - LAMINE-X FRONT & FOG LIGHT TINTS - EIBACH F&R ANTI ROLL BARS - WHITELINE ANTI LIFT KIT- CARBON LCR SPLITTER
    www.tdocuk.com
    Banned
    Aug 2010
    1,043
    Post Thanks / Like
    bloody cozzers. vultures!
    what engine code is it?
    has it been clunking on/off the power at all? the o/s drive shaft, is it the type where it has part of the shaft as a tube with a support bearing bolted to a bracket off the block?
    where it joins the gearbox is externally splined on to the gearbox drive. weve had a couple of these and transporters, sharans, tourans.... where rust has got into the spines and worn them out.
    leaving the car with no drive to the o/s shaft... so your able to just select first without using the clutch...... all they made was a slight metal grinding noise on doing so......
    the way to check this for certain is to put the clutch down as normal, select second at a stand still, lift the clutch up..... obviously the car doesnt move but does the speedo register any speed?? this means the clutch is fine and the gearbox is turning the diff... but with no drive to one shaft the sun/planet gears are spinning.
    Sep 2011
    Newcastle Upon Tyne
    13
    Post Thanks / Like
    Oh man... Was hoping nobody would mention the clutch.. Does anyone know what sort of price I'd be looking at for clutch and labour? Am not sure on engine code but it's a 2005 2.0tdi sline Quattro, the powers been fine murran until last night, will give your method a go today and let yous know..
    Cheers lads
  1. a3 quattro 170 bad vibration and noise at motorway speed
    By gixer600 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th September 2011, 15:42
  2. Replies: 0
    Last Post: 11th August 2011, 18:19
  3. audi ownership shattered by one drive on the motorway
    By tj1978 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2007, 17:14
  4. How Do I Drive My 2.0TDI?
    By emzino in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th March 2007, 20:25
  5. DSG Lost Drive / Gear
    By MrLapou in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th December 2005, 00:31
