AH FabricationsEM Tuning
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By marknjayne
Thread: Panel filter V Induction Kit?
    Yaseen1991's Avatar
    Aug 2011
    102
    Panel filter V Induction kit
    Just had my car de-catted, just a straight pipe from turbo to back, no silensors
    Next thing is air filter
    Ne1 recommend an induction kit like k&n or just a panel filter?
    All advice welcome thanks
    marknjayne's Avatar
    Sep 2011
    worksop
    423
    i have run an 80mm hose to the airbox and used the front fog pannel as a scoop with a BMC pannel filter
    monitered intake temps and they are very low when you get going
    made a bit better job of it now with a red silicone hose
    monster_munch's Avatar
    Dec 2011
    149
    Its a shame you didnt start this thread a week ago mate. On Sunday I took the K&N panel filter out of mine thats been in for 3k miles and threw it away. You could have had it.
    I fitted it to the car when I bought it, it made no noticeable difference really (at best I only expected it to rev a bit more freely anyway).
    I read alot about how the oil can block maf's and that some bloke has done lab tests and a K&N filter lets alot more dirt particles in your engine than a standard paper filter.
    I personally wouldnt say its worth it. A stock paper filter is good enough for an RS4 so I think its good enough for an A3
    marknjayne's Avatar
    Sep 2011
    worksop
    423
    the stock filter is good enough as monster munch says,i find the BMC gives very very little noticeable difference really (and the BMC are not caked in oil like the K&N),it was the cold feed that made a difference and cleaning the air flow meter (well getting a new one for me)
    Yaseen1991's Avatar
    Aug 2011
    102
    Hmm i really wanted a k& n for the sound difference loolll still in a pickle...
    marknjayne's Avatar
    Sep 2011
    worksop
    423
    defo dont get a K&N,they over oil them and the oil coats the air flow meter and knackers it,there are many out there,i went for BMC as i say
    Yaseen1991's Avatar
    Aug 2011
    102
    So just a panel filter? Or leave it standard lol
    marknjayne's Avatar
    Sep 2011
    worksop
    423
    panel filter with a cold feed IMO
    Yaseen1991's Avatar
    Aug 2011
    102
    Wats the best way to put a cold air feed in? Lol sorry for bein a dumbo aha
    warren_S5's Avatar
    Oct 2007
    7,157
    Unless you increase the surface area of the filter media you're not really going to see any benefit. I ran a panel filter for a few weeks when I was contemplating keeping my last cars engine cover..... It was sh1t.
    Audi S5 3.0V6T Coupe Black Edition
    marknjayne's Avatar
    Sep 2011
    worksop
    423
    if you look at the pics up there you will see i used an 80mm hose,used an 80mm hole saw and drilled the corner of the box,then used one of these and removed the blanking plate on the fog,really does make an improvement especially once above 40 mph,plugged the laptop in and monitored the intake temps and they dropped massively so the ecu will advance the ignition timing and adjust fuel to suit the colder temps so giving more power/torque
    marknjayne's Avatar
    Sep 2011
    worksop
    423
    Quote Originally Posted by warren_cox View Post
    the surface area is fine,increasing it wont make a difference as the air flow meter is still the same diameter,its the temp of the incoming air,colder air is more dense and combustible so gives increase on power
    briner likes this.
    warren_S5's Avatar
    Oct 2007
    7,157
    Quote Originally Posted by marknjayne View Post
    The chap who designs ITG filters for Renault engined F1 cars tells me otherwise. Whilst the MAF presents a diameter restriction the turbo basically sucks as hard as it can, and it pulls air faster through a larger media head (so I'm told). I'm guessing to use a basically analogy, if you send cars through a one lane tunnel at 60mph, then at 80mph, despite the restriction you still get more through. A filter with bigger surface area can supply whatever is requested. I have to hope he's right as he does it for a living, assuming I've explained it right!
    marknjayne's Avatar
    Sep 2011
    worksop
    423
    it is correct but the standard filter flows enough air IMO,increasing the area of the filter will make minimal difference (as has been proven by many people on here),its the intake temps that make more of a difference,when you run race cars though that all changes as they dont tend to run air flow meters
  1. Panel Air Filter or Induction kit?
    By JCAVY11063 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2011, 21:44
  2. Whats the best induction kit / panel filter
    By higher1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2011, 01:08
  3. Panel Filter vs. Induction Kit
    By A3chase in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st June 2010, 21:04
  4. Induction Kit v Panel Filter on 2.0 TDI
    By G40DP in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd January 2008, 15:55
