Inside the end of the dashboard on drivers side? Pull driver door WIDE open, then you can see dash end panel. Open end panel with flat ended screwdriver and turn panel round and 'should' have list of fuses
Not sure. Just checked my manual and no reference to rear lights. Rear brake lights are in by the battery fuse box (F29 from memory).
I'd suggest getting a powerful torch and checking the in car fuses (if you shine fuse right at end of each fuse) you may be able to see if any are blown. Pain, but it's better than guessing! Must be in different locations in each car if it's not listed specifically.
