EM TuningUnicorn
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By N8
Thread: RS4 Style Engine Start Button for S3/A3 8P3 Alternative
    Sep 2011
    Cambridge
    Post Thanks / Like
    First of all a massive thanks to Audi Retrofit as they inspired this little project and it was there instructions that I used to get this working.
    The only problem with their solution is that it cost well over £100 to complete as it used all original Audi parts. This made it too expensive for me given that it's just a little gimmick and really not required, That said it does put a little smile on my face every time I use it. My solution requires nothing more that a switch which cost £17.20 and a small length of speaker cable. It took about 2 hours to complete and was fairly easy. The button I used fits perfectly in the original cigarette lighter hole although I had to slightly adapt the buttons retaining nut to get to fit in the housing. I have also moved the lighter in the space next to the Aux socket.
    For a step by step guide;
    Audi Retrofit
    The switch I used;
    Buy Push Button Switches Switch,PB,vandal res,32mm,flush,SPCO Bulgin MP0050 online from RS for next day delivery.
  2. Thanks Baza1819 thanked for this post
  3. # ADS
  4. #2
    18,284
    Post Thanks / Like
    This was my original mod tbh which I advised Marc how to install, I had the RS4 starter left over from my S4 I was going to install into, but sold the car, hence fitted to my A3, glad to see its still being used.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
  5. Likes N8, warren_S3 liked this post
  6. #3
    Baza1819's Avatar
    Tdiiiiiiiii 170 quattro.......
    Jan 2012
    Sunderland
    107
    Post Thanks / Like
    Just been reading your step by step guide of retro fit button start - awesome is all I can say.......... Love it !!
    That's why this forum is such quality !!
  7. #4
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    The Unit
    15,248
    Post Thanks / Like
    Nige is right
    rikbbb likes this.
  8. Thanks NHN thanked for this post
  9. #5
    Sep 2011
    Cambridge
    Post Thanks / Like
    It was a good idea. I'd love it OEM but just can't justify the price.
  10. #6
    digzz's Avatar
    Leave It YEAHHHHHHHHHHHHHHHHHH
    Jan 2009
    London
    957
    Post Thanks / Like
    Quote Originally Posted by rikbbb View Post
    Audi Retrofit
    The switch I used;
    I suppose you still have to have the key in the ignition to start the car. Right ?
    "Digzz" Work In Progress
    http://www.audi-sport.net/vb/new-a3-...-progress.html
    Parts List For a 2009-2010-2011 Conversion for a Pre-2004-2008
    http://www.audi-sport.net/vb/new-a3-s3-sportback-8p-chassis/121130-parts-list-2009-2010-2011-conversion-pre-2004-2008-a.html
    2003 A3 2.0 TDI 3 Door – Panther Black - Full Front End Conversion 2011-S3 Rear bumper- L.E.D Lights - S-line Flat bottom Steering wheel - S3 Pedals - S3 Vents
  11. #7
    Sep 2011
    Cambridge
    Post Thanks / Like
    You still need the key to turn on the ignition and turn off the immobiliser.
  1. Building an RS4 alternative - Start with an S4 or a 2.0TFSI??
    By Bad Sir Culation in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th November 2011, 16:47
  2. Engine Start Button Upgrade
    By S6 LeMans in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 25th February 2010, 11:14
  3. RS4 Start Button
    By JohnboyC in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th September 2009, 10:31
  4. RS4 Engine start button on S3
    By klik in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th June 2008, 18:32
  5. Engine start button from RS4
    By terrymcg in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd June 2007, 21:49
