Badger5Chris Nott
Results 1 to 8 of 8
    Jul 2011
    is water dmg to ECU a common fault?
    I'm currently having a right mare with my A3 mainly relating to the glow plug light flashing and the car going into limp mode.Had it scanned when it first started and then the car was fine and the light stayed off, one of thje faults was water on the ecu. The light goes on and goes of for a past time days at a time when its off no problems the car runs smooth and is lovely but when it decides to come on its just a ball ache.Could water dmg to the ecu make it be like this? I'm going to get it scanned again to see if any other faults come up but its doing my head in
    Khufu's Avatar
    West coast of Scotland
    5,693
    it would be handy to know what the scan said. Why do you think it was water on the ecu? If water has got in to the multiplug you could get all sorts of problems & they would get worse if the terminals rust.
    Pipsqueak's Avatar
    Jan 2012
    Glasgow
    117
    Khufu
    Quote Originally Posted by Khufu View Post
    Khufu. Sorry to post off topic but you live in the same neck of the woods as me. I was on the retro fit white clocks thread but found you here. Who fitted your white clocks/dis for you? I've got a chance of a set. Can you post on that thread or PM me? Again sorry all for off topic
    27,007
    TBH the ecu is fairly well sealed so finding it hard to see how thats possible even in the plenum chmaber, but hey nothings impossible, but yes as Ewan asks, please post a vcds log so we can help further.
    Jul 2011
    here is the faults that came up on the first scan going to be booking it it angain to get another diagnostic and see what htye say needs to be done
    18353 - Control module 1 for cooling fan - output short circuit - intermittent
    18359 - Radiator fan 2 - movement restricted / jammed - intermittent
    17055 - Cylinder 1 glow plug circuit
    16610 - throttle pedal position sensor
    18041 - accelerator position sensor 2
    27,007
    Hows that denote water in ecu mate, I've had those faults when my turbo was on its way out, strange to show errors like this for turbo, but it did show some of these, thats not to say thats your issue.
    Jul 2011
    i knwo its not a fault that came up but teh garage that done the diagnostic said it woudl be advisable to check to see fi there was any water dmg so not sure if that is the case or not
    well goign to get it booked in againa nd see what solution to my problem they say just hope its not an expensive one
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Had the bottom three faults in the winter a couple of years ago. Thought it was a faulty accelerator pedal unplugged it, plugged back in and no more problems.
    Those errors might bear some relation to turbo failing like you mention Nigel, as mine had to be replaced few months later.
    VCDS USER
  1. Common fault code? 8P S3
    By 1animal1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th February 2011, 13:49
  2. common fault?
    By matboh s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th September 2010, 13:36
  3. ALARM IS A PEST (common fault?)
    By sline86 in forum General Technical / How To
    Last Post: 21st June 2010, 19:44
  4. 2.0 FSI turbo common fault?
    By tmitch45 in forum General Technical / How To
    Last Post: 11th July 2007, 17:42
  5. Common Fault?
    By doeboy in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th May 2006, 15:08
