EM TuningChris Nott
    1inchpunch's Avatar
    Apr 2011
    Glasgow
    449
    Rear brake replacement
    Will be replacing my rear discs and pads this coming weekend hopefully and just wondered if anyone out there could confirm 2 of the tools required.
    The first is the bit required for removal of the carrier. It looks like another one of those 12 point spline jobies, does anyone know what size? I heard it was M14 which is convenient as that's the only size of got, however it appears to be smaller so I need to order the right size.
    Lastly. I read somewhere that you need a special Audi tool to retract the piston. Is this right? I've always just used a C clamp in the past.
    the crisis mobile BMW Z4C 3.0
    It's quick and it sounds bloody good.
    1inchpunch's Avatar
    Apr 2011
    Glasgow
    449
    Should have clarified that it's a 2.0tdi 140 with DSG if it makes any difference.
    27,079
    Grab a wind back tool from halfords & a set of spline/hex sockets, dont buy singles as its expensive, that way you will have a set for any future jobs, make sure you unscrew brake fluid cap.
  1. A6 Avant - rear tail gate brake light (highmount)....where to get a replacement.
    By tullA6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th September 2011, 22:02
  2. Rear Brake Pad Replacement.
    By a3a3a3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th May 2011, 03:34
  3. Rear brake pad replacement
    By stevebuba in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th June 2010, 20:09
  4. Scraping Noise from rear? Brake and pad replacement? or stone stuck?
    By parin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th June 2009, 19:29
  5. Rear Brake Pads & Disc Replacement
    By maddoggydawg in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th January 2009, 20:43
