Results 1 to 7 of 7
Thread: ECU Error codes
    Nov 2011
    South Yorkshire
    169
    ECU Error codes
    I dont see any errors when turning the engine, however could there be fault codes in the ECU which could affect the performance of the car?
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,548
    Mate do you have vagcom , or if you cant find any faults take it to statllers in sheffield for steve jnr to have look at it for u...
    Nov 2011
    South Yorkshire
    169
    No I dont have vagcom. I just want to make sure I dont have any faults which are affecting the performance of the car.
    Nov 2011
    South Yorkshire
    169
    what is statllers in sheffield? and how much would it cost?
    27,096
    If you're that concerned then best bet is to buy vcds to scan it now & again, assuming its just a precautionary thing or do you actually have any problems currently?
    marknjayne's Avatar
    Sep 2011
    worksop
    423
    yes ,for example the air flow meter could be "within" its perimeters (lets say its telling the ecu its 35 deg C when its only 5 deg C) and sending the wrong signal which will cause power loss as the ecu will be adjusting fuelling and timing to suit the hotter intake temp,there are other things too which can effect the engine and not throw a light
    im in worksop,dont have vag com or vcds but have code readers and data readers so i can monitor things like the air flow meter etc..and im free
  1. A3 3.2 error codes
    By simonk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th November 2010, 19:12
  2. Error codes
    By dualmono21 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th February 2010, 21:55
  3. Error Codes
    By SDO in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2009, 12:18
  4. Some error codes
    By 0w3n in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th June 2008, 20:04
  5. Error codes!
    By S4ZippyZoo in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2004, 12:43
