AH FabricationsVolks Autos
Results 1 to 7 of 7
Thread: Boot Light
    Jun 2010
    41
    Boot Light
    Just went to change the bulb in the boot light as it blew the other day.
    Putting the exact same bulb in, and it doesn't work?
    Checked the interior light fuse in the fuse box and its fine?
    There isn't one for the boot light so is it on a different fuse/circuit?I
    Thanks alot.
    Brad.
    Fossie
    Rhubarb Triangle
    3,969
    Have you tried switching the ignition on and off to reset the fault ?
    L80EWY's Avatar
    Sep 2009
    331
    Think you've got to shut the boot and open it again as well to reset the boot light
    Fossie
    Rhubarb Triangle
    3,969
    And possibly lock/unlock because the boot light can affect the alarm !
    Jun 2010
    41
    Oh jesus ahha!
    I'll go and try all of these in a sec!
    Jun 2010
    41
    Right, turned out to be the "shut the boot, lock the car, unlock the car, open the boot, light works"
    Stupid thing.
    Cheers guys.
    Aug 2010
    1,540
    but your forgetting its ecu controlled. the ecu will see its open circuit (due to the bulb being blown) and cut the power to it. doing what youve done insequence has reset it.
    but you'll also have an intermittent fault code in the central electrics ecu now.
  1. s3 boot light
    By Duktor in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2010, 23:09
  2. Boot light always flashing??
    By glossy555 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th December 2009, 18:12
  3. Should I have a light in my boot?
    By Chris128 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th December 2009, 09:43
  4. Help with the boot light
    By natedog in forum RS6 Forum
    Last Post: 6th October 2006, 11:03
  5. boot light
    By imported_migzy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th January 2006, 11:43
