Volks AutosSky Insurance
Page 3 of 6 FirstFirst 123456 LastLast
Results 81 to 120 of 219
Like Tree73Likes
Thread: Backdraft Motorsport S3 Endurance Race Car build
  1. #81
    JtotheD's Avatar
    Events Moderator
    May 2011
    Bournemouth, Dorset/ Wallingord, Oxon
    907
    looking good guys, looking forward to seeing it up and running etc!
    S3 8L Ming Blue 273bhp & 294lbft h
    Build/project thread
    check it out!
  3. #82
    Backdraft Motorsport's Avatar
    1.8T & 2.0TFSi Specialists
    Sep 2007
    206
    Follow Backdraft Motorsport On Twitter Add Backdraft Motorsport on Facebook Visit Backdraft Motorsport's Youtube Channel
    I think most of the parts that come off the car will be up for sale but not until we know we definitely dont need them! We are using an OBP pedal box with potentiometer for the drive by wire throttle. Are you needing a std pedal box and other bits Alex?
    Pictures of the door swaging:
    By removing the side protection and swages we have saved nearly 20KG on the doors. We still have the polycarbonate windows to go back in though. We have also done quite a few swages on the tail gate area and rear arches, as well as the gear shift platform etc etc. All can be seen on the pictures above.
    Steve @ BDM
    Milton Keynes VAG Independant Specialist
    Phone: 01908 648081 / Email: info@backdraftmotorsport.com
  4. #83
    Richh999's Avatar
    Dec 2010
    Beds/Cambs, Bristol Uni
    155
    Quote Originally Posted by Backdraft Motorsport View Post
    Do you use the OBP pedal boxes in your other cars? When I was choosing floor mounted pedal boxes for my project I heard alot of bad things about theirs breaking and what not when used heavily so I went for a tilton one instead.. Thanks
    Audi A3 2.0TDI Black Remapped, with S3 Exterior, Half Leathers, 18" Alloys, Xenons, Tints, Cruise, Armrest, FBMFSW and RNS-E with BT...
    Have VCDS either around bristol, term time, or beds/cambs during holidays/some weekends..
    16V Classic Mini Mid Engined RWD 1.8VVC http://www.16vminiclub.com/forums/sh...ad.php?t=28324
  5. #84
    964kevin's Avatar
    99
    Block face machined down to get the perfect finish.
    The block has been completly overhauled with a lot of time spent machining to get rid of any rust and defects. It's then painted to look as new. We are able to get a really good finish.
    Cylinders have been taken to 0.5mm oversize and are nicley honed.
    Cast Iron Block??
  6. #85
    Joe90k's Avatar
    Speed doesn't Kill!
    Apr 2009
    229
    Very neat, looks like a lot of time and effort has gone into this.
    Click above for my A3 Build thread!
  7. #86
    Sep 2007
    206
    This is the first time we have used an OBP box and it was off the back of a recomendation from one of our suppliers. Hopfully it will be man enough for the job. The floor plate we have made is very strong and perhaps we will look at strengthening the box if needs be. The OBP box looks good so we will see how it goes and then cast our judgment!
    Steve @ BDM
  8. #87
    Sep 2007
    206
    Quote Originally Posted by 964kevin View Post
    Cast Iron Block??
    The block is standard material, and has been finished with black wrinkle paint. A fair amount of work goes into making the surfaces on the block free of corrosion but the paint is not too expensive and can be bought on the bay for about £7-10 a can. It brings the block up like new.
    Steve @ BDM
  9. #88
    Sep 2007
    206
    Cylinder head & engine work
    As promissed here is some pictures on the cylinder head before and after.
    So here we have the cylinder head from the origional engine as it came off the car. As you can see, it's not very pretty but it's only cosmetic.
    Next step, head overhaul. Exhaust and inlet ports are ported, valve guides are replaced where needed, new valve stem seals fitted, valves seats cut, new Ferrea light weight valves are lapped in and seal checked, Integrated Engineering springs and retainers fitted as well as head skimmed and chemical cleaned.
    Intake flaps have been done away with and filled with plastic metal.
    ARP head stud kit pulls down the head onto block.
    Friendy likes this.
    Steve @ BDM
  10. #89
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    great work :D
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
  11. #90
    Sep 2007
    206
    24.08.12 update
    Over the past past few weeks we have continued work on the S3, and the parts continue rolling in. Both our race and spare gearbox have had a complete overhaul, including fitting Peloquins ATB front diffs.
    The spare engine is now in the engine bay for it's first dry fitting. We will be designing a custom front mount intercooler and working out cable lengths etc etc.
    We have fitted a complete set of Vibra technics 'race' engine mounts.
    Rear diff is fitted into the lighter R32 Ali rear subframe.
    Superpro Alloy arms also arrived recently. The car will be completly polly bushed with Super Pro bushes.
    cnahamilton likes this.
    Steve @ BDM
  12. #91
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,420
    Very nice indeed...funnily enough,mine has just been fitted with the same Superpro TCA/Antilift kit and bushes......love the porthole to the engine bay!
  13. #92
    jaydav2306's Avatar
    Whats the revo logo doing on the front? Is that some kind of revo race thing?
    2009/2010 | Audi S3 Black Edition Ibis White | Black Optics Pack | Fully Loaded | S-Tronic
  14. #93
    May 2012
    Carlisle
    311
    Loving this build, keep up the good work
  15. #94
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,915
    This is well worth the wait.
  16. #95
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,420
    You're going to love those arms when they're fitted....Here's a couple we prepared earlier.....
  17. #96
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    Quote Originally Posted by andyhough View Post
    Wow just found this thread and I'm double excited!
    X2
  18. #97
    downtothebone's Avatar
    Mar 2012
    Wimbledon
    220
    Quote Originally Posted by S3Alex View Post
    Like these - apart from the weight advantage what else do they improve over the OEM parts? How much?
  19. #98
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    Quote Originally Posted by downtothebone View Post
    Price is £400 + VAT for the pair, (price is from s3alex's thread)
  20. #99
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,420
    Quote Originally Posted by martinivw View Post
    Correct....that doesnt include fitting though.
    My first impressions are that it's a very useful upgrade.
    Come on down to my thread for a quick review.
    Time for a build thread....big turbo
  21. #100
    Sep 2007
    206
    2.0TFSi roller bearing fuel pump drive upgrade
    The latest addition to our S3 race car...
    BDM are proud to offer a roller bearing fuel pump drive kit upgrade. This kit is a truly ‘fit and forget’ solution to the high maintenance, problematic OEM fuel pump drive system.
    The OEM fuel pump is driven by a flat faced follower running off the cam shaft lobe. The problem with this design is that it’s simply overloaded and causes increased friction which accelerates wear. This causes cam follower, cam shaft and fuel pump failures and in some cases the damage is irreparable.
    But now with the roller bearing fuel pump drive kit, the worry of fuel pump follower issues are a thing of the past.
    Roller bearing follower & reprofiled camshaft lobe
    On the left is the OEM cover. On the right you can see the modification to accept roller bearing.
    The inside view of the roller bearing.
    The OEM camshaft lobe (pictured on the table) is also replaced for a newly profiled lobe.
    This upgrade works on K03 & K04 variant motors, early camshafts, late camshaft and schrick aftermarket camshafts.
    For more details please contact us.
    Steve @ BDM
  22. #101
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,420
    Really neat solution to the fuel pump......is it compatible with uprated internals,and what sort of maximum flow/bhp would it support?
  23. #102
    Sep 2007
    206
    It's compatible with std and modified engines and fuel pumps. The modification can also be carried out on schrick cams.
    And it's been tested vigorously. The kit will easily support 500 + bhp appliactions.
    Steve @ BDM
  24. #103
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,420
    It's compatible with std and modified engines and fuel pumps. The modification can also be carried out on schrick cams. And it's been tested vigorously. The kit will easily support 500 + bhp appliactions.
    Thank you!...I now have a couple of choices for when I run mine out of capacity!
  25. #104
    JamesS4cab's Avatar
    Mar 2008
    1,122
    This looks an awesome development on the feul pump side.
    But i have a question.
    With the std cam follower, it a pretty simple thing to replace on a periodic basis but with the new design, there is the re-engineering required, and more "moving" parts which i'm not sure how servicable they are?
    Can you help me understand how this new system is better than a std cam and cam follower?
    Sorry if its a dumb question..........
    "Dont get me wrong. Ugly girls need loving. Just not by me."
  26. #105
    Sep 2007
    206
    Quote Originally Posted by JamesS4cab View Post
    Hi James.
    I understand that a lot of people will be happy to just keep a watchful eye on the OEM follower and replace it when needed as its relativley inexpensive (so long as you dont have problems). But for people that don't want the hassle of checking every 5 - 10 K, this upgrade is fit and forget, so you should never have to worry about it once it's fitted.
    For performance applications it's perfect because it has been designed to withstand the extra stress and strain. The reduced friction from the use of the roller bearing will mean that wear any parts is negligible. The OEM set-up would be a real headache to keep an eye on. This is especially beneficial with an endurance car that needs to be going for 24hrs with as little time in the pits as possible ;-)
    Hope that helps? And no honest question is a stupid question.
    Steve @ BDM
  27. #106
    Sep 2007
    206
    Update 03.10.12
    Well its been another busy few weeks in the workshop but the BDM race car project is still slowly evolving and progressing. So here are some more pictures for you to cast your eyes on...
    This is the race engine. As you can see, it's quite busy in the engine building room. The latest addition/modifcation is the new oil filter housing.
    The OEM oil filter housing is completly replaced and gets rid of the plastic housing and OEM heat exchanger. This should be a much more robust design more suitable for a race car. It also gives us the use of a oil cooler that is thermostaticly activated. We plan to be able to sell this a complete conversion kit in the not to distant future.
    Parts include...
    • 06A > 06F conversion plate.
    • 1.8T 06A oil filer housing, oil filter & gasket.
    • Thermostatic sandwich plate.
    • Machined oil breather cap (which will be made to take dash 8 fitting which will go to an oil catch tank).
    • Mocal oil cooler.
    • Braided oil lines and aeroquip fittings.
    This picture clearly shows the oil temperautre sensor (blue plug) and the oil pressure sensor. Both will be connected to the AIM LCD dash and data logging system where the peramiters can be monitered.
    Another part we havent mentioned but should is the clutch. Spec have supplied us with their stage 3 clutch and lightened aluminium flywheel. The cluch will handle 517 lbft torque and the light weight single mass flywheel will help improve acceleration.
    A neat little touch. The air jack air intake fitting is hidden nicley in the fuel cap. Once the air lance is plugged into the fitting the legs shoot down from the car so that all four wheels are off the ground.
    Hard lines to the air jacks have been installed nicley, following the contours of the car where possible.
    The clutch & brake hydraulic fluid resevoir is fitted under the scuttle.
    The rear axel is sub assembled on the bench. We will use the std rear calipers to start with. EBC USR discs are fitted as well as Japanese firm, Endless brake pads. I know the name sound a little corney but they really do go for ever and the stopping performance is fantastic! We completed a whole 24hr race on 1 set of the Endless pads in the Gallardo.
    H&R rear anti roll bar is fitted as well as Superpro bushes.
    More to come soon
    warren_S5 and poli84 like this.
    Steve @ BDM
  28. #107
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,794
    looking really nice mate...
    When are you gonna come 'pimp' my ride???!!
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
  29. #108
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,420
    I have a Spec Stage 3+ on mine...you won't go wrong with the one you've got.
  30. #109
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    WOWSER ,this thread just keeps getting better
  31. #110
    Silky-S3's Avatar
    Is loving his new 8V S3!
    Jan 2009
    1,390
    EPIC EPIC EPIC!!
    S3 8V Sportback Stronic, Estoril Blue Crystal Effect, Black Interior, Adaptive Cruise with Stop & Go & Pre Sense, Super Sports Seats with Electric Lumber, LED Headlights, Interior Lighting Pack, Hill Hold Assist, Privacy Glass, Comfort Package, Technology Package with Audi Connect, Advance Key, Folding Door Mirrors, Extended Mono.Pur Interior, Front and Rear Parking Sensors, Audi Sound System.
    Build Thread Here!
  32. #111
    Dec 2011
    237
    Can't wait for you to do more its a really good read
  33. #112
    A3Kent's Avatar
    Different Gear
    May 2012
    1,066
    I want the air line and legs on mine!! Imagine that! Roll up to kwik fit..shoot the air in and bingo the car is up in the air..."4 Pirelli's please guv". Haha!
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
  34. #113
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    Just reading this for the first time. Best thread on here, amazing!
    Shocking to see the first photo of a lovely looking S3 then an empty shell when you stripped it bare!
    The level of skill involved here is next level, very impressive. Following this all the way
    ....................I'll make a build thread one day.
  35. #114
    Digzz's Avatar
    "Started From The Bottom"
    Jan 2009
    London
    1,383
    WOW i'M sPEECHLESS.....And I can't believe I'm reading this first time after so many months have past and I didn't notice this thread ...
  36. #115
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    Sorry for the dislike, stupid iPhone I was seriously turned on reading that last update! The engine looks amazing and so sexy, the work that is being put into this is stunning! Can't wait to see the assembled car
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
  37. #116
    Sep 2007
    206
    Thank you all for your kind words. Im enjoying writing the thread & it is good to look back at the start and see how it is slowly taking shape. So far we are very pleased with what has been completed. I think it shows our high standard of work quite well.
    It's going to be great once completed. Looking forward to getting it on track and at few ASN shows & events. Passenger laps anyone?!
    Steve @ BDM
  38. #117
    Sep 2007
    206
    Yeah the stage 3 will be more than capable. Are you pleased with your spec clutch? What do you use your car for Alex? Daily driver or track toy?
    S3Alex likes this.
    Steve @ BDM
  39. #118
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    What sort of power are you hoping to achieve from this car?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  40. #119
    Sep 2007
    206
    Quote Originally Posted by Westy View Post
    We are going to be using the standard K04 turbo so I think it will probably be around 360/370 bhp. Maybe a bit more. The head work should help imporve the power curve and turbo spool time. Once we have it all together we can find out the numbers. When the time comes we will get the figures posted up.
    Steve @ BDM
  41. #120
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    All this work and your fitting standard K04 turbo?
    Is it race regulations that it remains the standard turbo?
    I'd be going big with the work you've put into this build, but hey thats just my 2p!
  1. Backdraft Motorsport
    By big_mo in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2010, 10:53
  2. backdraft motorsport
    By timmys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2009, 11:46
  3. New member of the Backdraft Motorsport team saying Hello!
    By Backdraft Motorsport in forum The Welcome Section
    Last Post: 13th January 2009, 10:43
  4. Backdraft Motorsport Audi TT Silverstone 24 Hour
    By Backdraft Motorsport in forum Backdraft Motorsport
    Last Post: 29th July 2008, 09:24
Tags for this Thread
