Sky InsuranceRevo Technik
Results 1 to 14 of 14
    itwasntme187's Avatar
    OEM Installer
    Mar 2009
    North, East, South and West London & Dartford in Kent
    4,348
    Post Thanks / Like
    Lightbulb How To - Facelift Chome Climate Control Module Switches
    I have finally upgraded my climate control by adding the chrome switches from the facelift models to it.
    This 'How To' will show how it is done, i would say its a difficulty rating of 2 out of 5 (not difficult, just need to take your time and be patient)
    For anyone that is wondering why this mod was needed and why i didnt just swap over the unit directly to the car.... well i tried to test it out and i found that the new unit does power on and pump out air but when the A/C is turned on no air is directed into the cabin due to the air circulation flaps being changed, so its pretty useless in my pre-facelift A3.
    So here is what to do...
    Firstly get yourself a facelift climate control unit... these can be pricey, i picked one up for £60 on the bay.
    Then take out your existing climate control unit from the car. I have a double din unit so i just simply removed the rubber button strip above the climate unit and then just pulled the climate unit out by pushing it down off its top clips and then unplugging the cables behind it.
    Now you need to get both units apart. This part is really easy! you just need to have a T9 screwdriver and then get to work removing the screws in the back of the units.
    The old unit disassembly:
    unscrew 8 screw from the back of the unit (that little see-through plastic part is my custom ambient light under the unit):
    next carefully lift the 2 tabs at the top and take the back plastic off...
    then unscrew 6 more screws from the back of the electrics board:
    now this panel can be taken off to reveal the front panel
    The facelift unit disassembly:
    Unscrew 6 T9 screws from the back of the unit:
    remove the plastic cover and remove another 6 screws from the back of the board:
    now you have the front panel of the facelift unit...
    now we need to remove the switches from the panel. this is done by carefully moving the the black tabs out of the way and the switch should pop out of the front of the unit:
    do the same to the other side and to the old climate unit, you should now have this:
    now we need to get rid of the raised plastics on the old climate unit as the new chrome switch will not sit unless these are removed. You can dremel these out but as it was late when i did mine (1.30am) and i didnt want to make too much noise i just used a small set of pliers and got to work cutting them off (thanks Amar for this idea!)
    before:
    After:
    now the chrome rings from the new unit will not fit the old climate unit as the legs are slightly shorter and so need to be swapped over...
    Old rings on the left, new rings on the right:
    To do this the chrome one needs to have the small tabs carefully pushed inwards to release it (be very careful as these are really weak and can easily break)
    the old switches are easy as the front part of the plastic just pull off...
    now swap over the chrome rings and reattach the switches, then attach the new chrome switches to the old climate control face. Watch out for the spring and carefully push the chrome rings back into place
    Then just put the board and the rear plastics back together with the screws and you are done!
    plug it back into the car and admire your new shiny chrome blinging look
    Now since I had the facelift panel and the old switches i decided to make use of it so after a little 'modding' on the old switch i ending up with this:
    The facelift unit still works perfectly fine now just with the older looking switches on it. Since no modification was actually done to the facelift panel the old switches can come back off and replaced with another chrome switch if anyone wants to do that, or it can be used as it is with the older switches in place. So I am going to sell on the facelift unit as someone out there may need to replace their original facelift unit due to other sorts of damage to the unit or electrical faults with their existing climate unit.
    Hope this helps you guys out in the future
    DISCLAIMER: I will not be help responsible for any faulty climate control units after attempting this mod. If you do F*** up your unit then thats your own fault
    Ash
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    Bi-Xenons, Auto lights, S-Line Bodykit, FK S3 Grill, TTRS FBMFSW & Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims, Exclusive LED Kit
    Items for Sale
    My Blog & Build Thread: Ash.Net
    BBM: 2888DD52
  2. Thanks NHN, mikex709, FranA3, digzz thanked for this post
    Likes BlueSpark, digzz, Sandra liked this post
  3. # ADS
  4. #2
    Sandra's Avatar
    Sep 2010
    West of Scotland
    4,768
    Post Thanks / Like
    Very informative and well documented Ash. Looks good too. Well done.
  5. #3
    digzz's Avatar
    Leave It YEAHHHHHHHHHHHHHHHHHH
    Jan 2009
    London
    957
    Post Thanks / Like
    Lovely write up once again Ash...... .....I was thinking of just swapping over the unit...But as u know and a lot of people on ASN couldn't get the new unit's too work properly. Mind you thou ....I did hear somebody on ASN got it to work .....can't remember who thou.
    I'll definitely be doing this mod ....
    Thanks A lot Ash .....
    Keep them Mods Coming !!!!!!!
    "Digzz" Work In Progress
    http://www.audi-sport.net/vb/new-a3-...-progress.html
    Parts List For a 2009-2010-2011 Conversion for a Pre-2004-2008
    http://www.audi-sport.net/vb/new-a3-s3-sportback-8p-chassis/121130-parts-list-2009-2010-2011-conversion-pre-2004-2008-a.html
    2003 A3 2.0 TDI 3 Door – Panther Black - Full Front End Conversion 2011-S3 Rear bumper- L.E.D Lights - S-line Flat bottom Steering wheel - S3 Pedals - S3 Vents
  6. Likes Sandra liked this post
  7. #4
    OEM Installer
    Mar 2009
    4,348
    Post Thanks / Like
    so far the only guys i have heard of getting them working by swapping them straight over have been those with 57/08 plate Audis. this is because the flap change was being phased in so some of those cars will take the newer units and just work.
    as i explained when i tried it (i knew it wouldnt work but tried it still) the fan motor was ok but the A/C would not work. The light comes on as it should (light on when A/C on... light goes out when A/C off) but no actual cold air comes into the cabin so its a fail.
    Ash
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
    BBM: 2888DD52
  8. Likes digzz liked this post
  9. #5
    BlueSpark's Avatar
    Aug 2010
    South London
    280
    Post Thanks / Like
    Nice one Ash, Very detailed write-up once again.
    Ron
    Audi A3 8P2 2.0Tfsi S-Line Special Edition
    3dr Mauritius Blue || Full Leather|| BOSE || MFSW || Auto Lights/Wipers || Auto Dim Rearview Mirror || Heated Mirrors
    Mods: S3 Aluminium Pedals || S3 Vents || 2010 RNSE || OEM Bluetooth || Dension Gateway 100 || MY09 Rear Lights || Single Xenon Headlights
  10. #6
    Baffles's Avatar
    Oct 2011
    Walton-on-Thames
    193
    Post Thanks / Like
    Ditto - great write up. Might be giving you a shout in the future for that as well, lol.
    You gonna update the buttons (ESP etc) above? Have noticed that the MY11 facelift added another blingy chrome strip compared to the first facelift.
    A3 | 2.0 FSI | Mauritius Blue Pearl | Build Thread
  11. #7
    OEM Installer
    Mar 2009
    4,348
    Post Thanks / Like
    Quote Originally Posted by Baffles View Post
    I am not sure about the buttons, i kind of like the way they are now but i may consider it if the buttons come to me cheap. Its not on the list as a 'to-do' mod so i'll see how it goes.
    Ash
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
    BBM: 2888DD52
  12. #8
    *Müllërz's Avatar
    REVOlutionary
    Sep 2010
    420
    Post Thanks / Like
    great thread and wript up ash
    Why not use the buttons from the climate you got the other buttons from?
    For sale
    - A3 3 door sport interior cloth seats
    inc rear door cards
    -A3 5 door side skirts
  13. #9
    OEM Installer
    Mar 2009
    4,348
    Post Thanks / Like
    the climate control buttons cannot be easily separated, if you have a look at the above pictures you can see that the buttons are held onto the front fascia with what looks like rivets/glue.
    i did not fancy taking them apart
    also i read that someone had tried using the front panel fascia from the new climate units and put that on his old climate electrics but the buttons dont press correctly some of the lights dont line up either.
    Ash
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
    BBM: 2888DD52
  14. Thanks *Müllërz thanked for this post
  15. #10
    *Müllërz's Avatar
    REVOlutionary
    Sep 2010
    420
    Post Thanks / Like
    Thats a shame about the buttons
    Going to just wrap my switches along the sides brushed alu
    For sale
    inc rear door cards
  16. #11
    warrenlord's Avatar
    Apr 2010
    748
    Post Thanks / Like
    Surely you can just buy the switches ? Without the hole unit form Audi ?
  17. #12
    *Müllërz's Avatar
    REVOlutionary
    Sep 2010
    420
    Post Thanks / Like
    I believe ash has already found out you have to get the whole unit
    For sale
    inc rear door cards
  18. #13
    Jun 2010
    92
    Post Thanks / Like
    Sweet write up Ash. Bookmarked for future reference
  19. Likes itwasntme187 liked this post
  20. #14
    18,284
    Post Thanks / Like
    Quote Originally Posted by digzz View Post
    If it was on a pre mid 07 car, then its technically & physically impossible, some people have fitted & realised sometime later the flaps dont work properly, hence swapped it back.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
  21. Likes itwasntme187 liked this post
  1. any ideas on how to remove the climate control module?
    By bigblokey0 in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 12th February 2011, 12:22
  2. How to remove climate control unit switches/facia?
    By c_w in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th September 2010, 12:59
  3. Climate Control Module Removal
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd July 2010, 11:27
  4. Replies: 3
    Last Post: 13th July 2007, 10:53
  5. removing climate control module
    By DrX in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th September 2003, 08:30
