Sky InsuranceEM Tuning
Results 1 to 14 of 14
Thread: Start/Stop
    Feb 2011
    Falkirk
    296
    Start/Stop
    I've got a 2010 A3 2.0Tdi BE (140) I've had the car since the start of September now and the start/stop thing took a while to get used to but it ws great when I got the hang of it, but now it appears not to be working at all. Since probably the start of December anytime I come to a stop the symbol appears saying it is unavailable. The first few times I put it down to the car maybe needing to have warmed up properly before it would kick in but at the weekend I went for along run and still it wouldnt work. Cant seem to see much in the manual regarding it and I made sure that the conditions set in the manual were all met when trying it out again. Anyone else have this sort of problem or am I just doing something stupid?
    cheers
    Dazz
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    Not sure what the Audi system is like, but if it's anything like the mini system it deactivated itself if the air temperature was below a certain level, could be that?
    Factory: Phantom Black S3, BOSE, RNS-E, Adaptive Lights, Interior Lights, Auto Lights
    Added: Evolve Stage 2 Map, Evoms CAI, Milltek TBE Non-res With Special Tips Now At 360bhp & 385lb/ft, VWR 4 pots, H&R Springs, H&R Spacers, Sachs Clutch, '09 Rear Clusters, Pressed Metal Plates, TT Air Vents
    To Do list: Now that would be telling
    PM me for Weitec & KW coilovers
    cloughy's Avatar
    Sep 2011
    Berkshire
    515
    I now on my BMW it stopped working below 3 degrees or similar
    My wife's new A1 has the Audi Stop/Start system and it checks all sorts of things before it works. I will have a look in the Owner's Manual to see if it gives any further details.
    Dave R (h5djr)
    Helifella's Avatar
    Flying low level
    Nov 2011
    North Yorkshire
    330
    Follow Helifella On Twitter
    On mine I find the A/C will stop it activating, or if you press the A/C to 'on' the engine fires up, also low voltage on the battery will stop it working. I sometimes wonder if it knows when it gets home because apart from the first time I arrived home it has never wanted to cut the engine. It will trigger with the foot brake as well as handbrake. Also hand if you stall too - just dip the clutch and away you go. I think if it was faulty you'd get an amber caption, rather than the usual white one you stated.
    Regards
    HeliFella
    I.A.M. Member http://www.iam.org.uk/about-us/
    '61 spec, A3 Sportback S-Line Black Edition in Ibis White, EM Tuning upgraded LED extended interior XL lightpack,
    Duxback Glass Treatment, Diamond Vision front fog lights, shortened number plates,
    gloss black rear rings & black edition S-line wing badges. Blackvue DR550GW 2 channel in-car camera with Smart Power battery protection.
    Adam.'s Avatar
    Meow.
    Mar 2011
    Glasgow
    634
    If start stop had errors then it would flash up "start/stop error please visit dealership".
    XXXCorps's Avatar
    Nov 2011
    192
    If the outside temperature is below 4 degrees it will stop working, if you have automatic air conditioning and you have that set to very low or very high temperature; the start/stop system will disengage whilst the temperature in the car is attained...
    If you have all the electrics on; i.e. heated rear window, lights, a/c etc. this will affect the start/stop system too...
    2013 Audi TT 2.0 TFSI S Line Black Edition. Misano Red.
    Amplified Black Package. Comfort Package. Technology Package. Heated Seats.
    http://s1308.photobucket.com/user/xxxcorps/media/photo1_zps1e5c9a3f.jpg.html
    Feb 2011
    Falkirk
    296
    Thanks for the info folks, I did remember switching the AC off back when i got the car and that stopped the Start/Stop working but its always on now. Ill put it down to cold temperatures for now but ill keep an eye on it for when the temperature gets a bit warmer.
    Dazz
    Out of interest and further to my earlier post these are some of the items checked by the Stop/Start system on my wife's A1.
    Basic conditions:
    The driver's door must be closed
    The driver's seat belt must be buckled
    The bonnet must be closed
    The vehicle must have been moving at over 4km/h since the last stop
    Engine does not switch off if:
    The engine has not yet reached the minimum temperature required for stop/stop mode
    The interior temperature selected on the air conditioner has not been reached
    The exterior temperature is very high or very low
    The windscreen is being defrosted
    The parking aid is switched on
    The battery charge is too low
    The steering wheel is close to full lock or the vehicle is being steered
    Reverse gear has been selected
    The vehicle is on a steep gradient
    So it quite a clever system and I'm quite looking forward to getting it on my next A3 which is due for delivery in March.
    On my new A3, which will have the s-tronic gearbox, the system will work when you stop the vehicle and keep your foot on the brake. The engine will start again automatically when you take your foot off the brake. You can also control whether or not the engine is switched off by varying the amount of pressure on the brake pedal. If you brake gently in stop and go traffic or before turning off at a junction, the engine will remain running while the vehicle is at a standstill. As soon as you press the brake pedal harder, the engine will be switched off. I can see some controlled use of the brake pedal being necessary.
    Dave R (h5djr)
    Feb 2011
    Falkirk
    296
    Unhappy
    Thanks for the list, im sure all of those requirements are met. the only thing I can think of would be the external temperature although it has been up around 8C some days. I'll keep an eye on it and if it is still not working after the temperature picks up and stays a bit warmer...maybe july
    Feb 2011
    Falkirk
    296
    Well since the temperature is back up ive noticed that it still dosnt work haha, im going to do some final checks tonight/this weekend before i give audi a phone
    Mar 2012
    South Wales
    16
    I noticed myself that it does seem really picky!
    Generally on my daily commute to work the first bit is motorway and the car is normally nice and warmed up by the time I get off at my junction. There's normally a wait at the lights there and the start/stop normally kicks in. But every now and then it doesn't, whether it was slightly colder or there was slightly more drain on the car I don't know.
    For the most part though it works really well so if yours is not coming on at all I suspect there's a fault of some description there. Its certainly not cold enough now to stop it coming on I would think.
    Good luck!
    audigex's Avatar
    Jul 2011
    555
    Mine seems oddly choosy - sometimes turning off when the temperature is only 1/4 of the way up, others not.
    It could just be that your temperature setting hasn't been reached yet - I find mine works best if I set it to the same on passenger and drivers side (presumably they both make the other think they're not quite the right temperature) or if I have the temperature slightly higher than normal. One of the conditions, even if the AC is off, is that the climate control temperature has been reached.
    Mine also sometimes doesn't turn off if my iPod is plugged in and charging, presumably that tips some current draw meter over the edge.
    That said, I can't be the only one who still doesn't trust it to turn back on when I'm sat at the lights? Although it does have the handy side effect that if you stall, it re-starts if you drop the clutch again quick enough.... that's a nice little feature.
    Ibis White A3 Sportback Black Edition.
    2.0 TDI (170) Quattro
    Pics
    Feb 2011
    Falkirk
    296
    Well on Sunday after being at the Crieff Audi meet it started to work again no idea why, nothing has changed all the settings are the same as before but now it just works.
    So I'll keep a check on it, maybe all it needed was some nice sunshine for once haha
  1. Stop Start Auto Start Up
    By PaulTheo in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 10th March 2013, 14:53
  2. Start Stop Question
    By MattyW19 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th March 2011, 00:14
  3. start stop engine light on
    By madmark in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2011, 22:13
  4. Auto Start/stop worth it?
    By rosscotdi in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 1st September 2010, 18:30
  5. New A3 automatics pioneer stop-start
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th November 2009, 22:25
