Sky InsuranceChris Nott
Results 1 to 11 of 11
    Aug 2009
    50
    Annoying Rattle from Rear, Ideas ?
    I've got an annoying rattle that comes from the rear passenger side on bumpy roads in my 3dr 2.0TDi Quattro 8P, it's also there when you start to accelerate from about 1400rpm, Is there a speaker that is kept in that area, if so how do i get to it to check if it's loose?
    Any advice on this rattle would be good as it's starting to get annoying now :-(
    Cheers.
    Sheikh's Avatar
    Aug 2011
    Surrey
    658
    I have the same problem, if i have the rear seats down its about 20 times worse!
    55' BMW 330Cd M Sport
    The ones that have been left behind:
    • 2004 VW Golf R32
    • 2004 Audi A3 2.0 TDi Sport
    • 2000 BMW 318i M Sport
    Private plate for sale: Y 7RYY
    Aug 2009
    50
    I have thought it might be something to do with the seats or even the parcel shelf, but it's still there when I have been out without the parcel shelf. I cant find any way to adjust the rear seats, but I think it's def in the RH rear passenger "door card" area, even though it's a 3dr.
    Nov 2010
    Leeds, UK / Antibes, France
    223
    A year ago I had rattles from the rear which sounded like a mixture of the parcel shelf and rear shocker top mounts. Audi said it was the stone guards at the rear...? I had them replaced back then and the same noise has just started again.
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    Is it 'plasticy' sound? If so its most like the plastic guards on the rear arms. I had this issue with mine and removed them, problem solved
    For Sale -
    A3 rear wiper motor and arm
    A3 air vents
    56plate A3 S-Line full speaker system including amp
    rockape's Avatar
    Per ardua
    Dec 2010
    North East
    284
    I have a similar noise from the same area but its more like a clicking when going over bumpy roads. To me it sounds like its coming from the seat release catch but I've had a good look at it and can't find anything loose. Tbh this car is the worst I've had for rattles and creaks particularly in the cold spell.
    Had the rattling stone guard too which I cured with a tie wrap.
    For sale:
    RS6 18" alloys
    S-line 8p2 chrome grill
    Pm me.
    Aug 2009
    50
    Last night I did some strategic pushing in the problem area, this morning on my trip to work the noise is now much better, still there slightly but very much better. From this it looks like it's to do with the plastic side panels, is there a guide on here to show how to remove them from this area ?
    I will also check the platsic guardss on the rear arms though, just in case.
    Aug 2009
    50
    Is there aguide anywhere which explains how to take apart the rear "door card" area? that would be really helpfull so I can take a proper look ;-)
    Aug 2010
    1,540
    those stone guards you speak of are the most likely cause.
    at work i must have binned around 10 pairs in the last year.
    just throw them away, for the stone guard protection...... in fact looking at them i think theyre more of an aero dynamic aid for the underside more than protection of any vunerable components.
    pretty much pointless for the trouble they cause.
    Nov 2011
    Had the same problem, Audi just removed the stone guards. No noise since.
    ElliottB's Avatar
    Audi A3
    Nov 2011
    Hull
    144
    How do you remove the stone guards because i have this same problem
    I am here: http://maps.google.com/maps?ll=54.085851,-0.204763
    Audi A3 2.0 TDI - S3 Intercooler - Darkside Developments Hard Pipe Boost Kit - EGR Delete - Milltek Non-Res Decat Exhaust System - Performance -Torque Custom Remap 187BHP + 335lb/ft
  1. Truly annoying rattle
    By landopanda in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2009, 16:46
  2. Very annoying suspension rattle??!
    By Jonezy87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th February 2009, 14:51
  3. VERY annoying rattle
    By imported_gek in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2005, 21:43
  4. Rear roof rattle - SO annoying
    By benk in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2003, 13:41
  5. Annoying Rattle
    By amoffat in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2003, 22:15
