Sky InsuranceChris Nott
Results 1 to 16 of 16
    Jan 2012
    12
    Rear window washer not working (water scoosher)
    Hello,
    My rear washer does not squirt any water although the wiper works.
    Where is the tube routed and is it hard to get at and repair? The passenger footwell doesn't seem to be wet but I've yet to peel back the carpet due to fear of damaging something!
    Could it be something else?
    Thanks folks
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    Possible a blocked jet.
    Had the issue with one of the lads car in work.
    Stripped the boot down, removed the pipe from the motor and tested.
    Water came out.
    So striped the jet out of the motor and cleaned it through.
    Worked fine now.
    I would deffo take the pipe off the back of the jet and make sure water is coming out before stripping the interior out.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Jan 2012
    12
    Quote Originally Posted by scott b5 View Post
    How would I do this? Not sure what you mean...from the inside?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    Quote Originally Posted by cshy View Post
    Yeah.
    Open boot.
    Remove trim.
    Pull pipe off.
    Fire rear washer jet.
    If water comes out of pipe inspect washer jet.
    I should have taken pics when I did it but never had time, the joys of doing it during working hours.
    Jan 2012
    12
    Yeah.
    Open boot.
    Remove trim.
    Pull pipe off.
    Ok, so is removing the trim complicated? Bare with me me sorry...just scared to be yanking bits off!
    buffalino's Avatar
    LIVING THE GOOD LIFE
    May 2007
    barcelona
    75
    i had the same problem,, i just pushed a needle in the jet hole ,,and that worked fine!!
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    There is two screws and a series of clips from memory.
    It does need a good yanking to get the clips away from the body.
    Quote Originally Posted by buffalino View Post
    It works for short term but you're potentially pushing the dirty that's blocking the hole back in to jet for it to block it again.
    Remove it and clean it would be better.
    jasonc's Avatar
    Jun 2011
    Reading
    140
    I had the same problem with the blocked nozzle and no water coming out. Fix was simple on mine:
    1. Remove the plastic cover at the bottom of the wiper blade (it just pulls off)
    2. Pull the jet nozzle off (again just pulls off - may be stiff)
    3. Test the washer - if it works then the nozzle was blocked
    4. Either clean the nozzle by soaking it in vinegar and poking a bit of wire through (a kitchen tie with the plastic removed is good) or just go to an Audi dealer and get a new one for 4 quid
    5. Push the jet nozzle back on (if you bought a new one it will be very stiff) and replace the plastic cover.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    Quote Originally Posted by jasonc View Post
    Thats so much better than my way. lol
    dav150n's Avatar
    Sep 2011
    north east
    43
    dont suppose you know the part number??
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by dav150n View Post
    The dealer will not need the part number - he will already know it !
    dav150n's Avatar
    Sep 2011
    north east
    43
    makes things a lot easier though if i tell them!
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    Depends on the part guy.
    Mine gets funny when I give them part numbers.
    I don't bother any more.
    Fossie
    Rhubarb Triangle
    3,969
    Rear washer jet for an A3 is hardly taxing the parts department - same fitting on all A3's
    jasonc's Avatar
    Jun 2011
    Reading
    140
    Agreed - I took my old one in with me and the guy didn't even look at it, just went straight to the rack behind him and grabbed one.
    Jan 2012
    12
    Took jet off, tried to blow through it, no joy...poked pins in the holes then blew through again...joy.
    Moment of truth when I go back out into work car park to test it!
  1. Rear window washer not working?
    By Jonezy87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2013, 15:26
  2. Water in footwell + rear washer jet not working + aircon knackered
    By munchkincoupe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd February 2011, 14:57
  3. No water from rear washer
    By SiGainey in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2011, 09:50
  4. Rear washer not working
    By banoffee in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd November 2009, 14:18
  5. Avant rear washer water gone...
    By chazzy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th January 2006, 20:55
