AH FabricationsChris Nott
Results 1 to 7 of 7
    Feb 2011
    Coventry
    59
    Advice on spacing wheels. 2.0tfsi sline sporback 18"speedlines
    Hi all,
    I've been Thinking for a while that the rear wheels on my sportback appear to sit quite far in the arches. Should I space them out and if I do how much? and do I need any sort of re alignment after? Is it quite a normal thing to do or have I possibly got the wrong wheels fitted
    Any help would be great, thanks
    Audi A3 2.0TFSI S line DSG SB BLUEFIN
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    i recon 12mm will do it nicely if they are the standard offset wheels which are et54 , N8 is the wheel man he will advise you better soon enough
    ​She is back on the road yay!!
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,402
    Follow Brodster On Twitter Add Brodster on Facebook
    I was going to ask the same question. Having posted pictures of my S3 and compared it to others I would like to alter the stance of the car by fitting spacers just to give it a more aggressive stance. Is it as simple as wheels off, spacers on and longer bolts fitted and then balance wheels??? My car is standard 8P2 S3.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    yep easy as wheels off spacers on , get longer bolts (if required) then wheels on job done , don't think you need to balance the wheels again as they should be balanced anyway
    Brodster's Avatar
    Mar 2011
    Scottish Borders
    3,402
    OK then thats sorted then. What is the best size to go for......10mm or 12mm and should front and back be the same size. Just want to give the car a more aggresive stance.
    warren_S5's Avatar
    Oct 2007
    7,163
    Personally on S3 I'd go for 10mm. With it being lower than the other models any more than that will result in rear arch rub. You could go 12mm but it will mean you need to whip the rear arch liner screw out of the top of the arch.
    McGard locking bolts (around 40mm), and then some extended wheel bolts M14 x 1.5 (36-40mm) will be fine.
    Make sure you get the right sort (radius fitting bolts) as otherwise you'll end up with terrible wheel wobble!
    You could go 12mm on an A3 with higher standard suspension.
    Audi S5 3.0V6T Coupe Black Edition
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,291
    On the A3 the best and most popular option is 10mm front and 12mm rear.
    Give me a shout if you need any prices or info.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
  1. 20" BBS Speedlines
    By b19ctr in forum For Sale/Wanted - Audi Parts
    Last Post: 27th August 2011, 22:31
  2. new 19" speedlines
    By herrmax in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th August 2011, 09:40
  3. Rear Wheel Spacing Advice
    By BlackSportback in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th April 2011, 21:14
  4. Replies: 3
    Last Post: 2nd December 2008, 14:44
  5. Spacing wheels
    By domcj in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2003, 07:43
