Monster MotorsportEM Tuning
Results 1 to 8 of 8
    Jan 2012
    6
    Question Is my alternator nackred?
    I recently bought myself a 2004 Audi a3 fsi sport, but the traction controll light came on and the battery light keep coming on when I go up a hill then goes off now and then, the car had a new battery fitted a month ago too, any ideas?
    warren_S3's Avatar
    Oct 2007
    6,195
    Put a multimeter on the battery terminals to see what voltage the cars putting out before starting it. Much less than 12v is a warning sign. Car should be able to generate upto 14.4v when running.
    Does the car labour much if you turn on aircon or full beam lights?
    If it is alternator the new battery will eventually suffer. Also check o make sure earthing connections to the chassis look clean /good.
    Audi S3 Panther Black [2011] Build Thread
    Mods: Revo Stg2, Blueflame TBE, Eibach Pro springs, R8 oil cap
    On order: Audi S5 3.0V6T Coupe Black Edition, Phantom Black [Due 26 May 2014]
    Planned Mods: Revo Stg1+ with DSG map, Revo CAI, custom exhaust, H&R Trax spacers, EM Tuning LED interior lights, R8 oil cap, Porsche coolant & brake fluid cap
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Also put a voltmeter across the battery and get someone to try and start the car and see what the voltage drop is under load. It should still put out 10+ volts. Also check battery fluid levels if its losing voltage up hill
    Jan 2012
    6
    Il go in past a garage on my way home, I never noticed it labour but the battery light came on every time I wheel spun (it was icy)
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Are you sure it was the battery light ?
    Jan 2012
    6
    Well it was a red rectangle with a positive and a negative inside of it. It wasn't the ESP light because that's on all the time
    Jan 2012
    6
    Is it possible for a faulty alternator to make the traction control light to stay on?
    Jan 2012
    6
    Oh and I forgot to say, before I bought my car the dealer said that he changed the battery because the car wasn't starting great, maybe because it was dead because the alternator wasn't charging it, that was about 2 weeks ago
  1. Alternator
    By s3_stig in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th May 2010, 23:19
  2. Alternator Help:
    By n30 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th April 2009, 08:51
  3. Alternator
    By otis_b in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th September 2007, 13:30
  4. Where Is The Alternator?
    By Biggles in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th May 2007, 16:40
  5. S3 Alternator
    By HmanS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2007, 11:16
