Monster MotorsportBadger5
Results 1 to 7 of 7
    Jan 2012
    6
    Will these alloys fit?
    Hi, I'm new to the forum as I just bought my first Audi the wheels on my car are awfull and I'm away to buy new ones, I did a search but it confused me even more, will these fit my 2004 Audi a3 fsi sport? 18" ALLOY WHEEL AUDI RS4 VW GOLF TRANSPORTER T4 SEAT BLACK POLISHED SET OF 4 | eBay
    warren_S5's Avatar
    Oct 2007
    7,164
    Audi S5 3.0V6T Coupe Black Edition
    Mar 2011
    Cleveland
    983
    Nov 2011
    South Yorkshire
    169
    Are 8J not too wide? or ok to put on?
    warren_S5's Avatar
    Oct 2007
    7,164
    1) You can fit upto a max of 9J with the right offset, tyre choice and suspension geometry
    2) The maximum recommended offset is ET45, although I'd imagine you could just exceed this (maybe ET42 with the right settings / tyres)
    These parameters suggested above are dependent on whether you are running manufacturer specified ride heights or have slammed it on it's arse.
    Whip rear screw out of rear arch liner if you are getting minimal rubbage
    ALWAYS refer to a suspension specialist if you know you are likely to be pushing the limits
    ALWAYS get a full geometry check if you are arsing about with settings (tyre footprint is the only thinkg between you, life and hedge)
    c_w
    1,061
    They'll probably be ok but the car will have that distinctive "aftermarket" alloy wheel look about it, as the offset is about 11mm different plus a 1/2" extra width means the wheels will sit out about 17mm more than the average factory alloy. It helps brings the wheels out though which the A3 could do with, particularly on the back axle, the front less-so.
    *Müllërz's Avatar
    REVOlutionary
    Sep 2010
    479
    i Have set for sale of you want them
    Swap
    2008- A3 Sportback/5 door rear black edition bumper with parking holes
    Will swap with no holes sline bumper preferably white
  1. Will these A5 alloys fit my S3?
    By miss_lucy in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2011, 17:40
  2. alloys will these fit?
    By kirsty76 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th January 2011, 12:31
  3. Will these alloys fit?
    By finesse in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2010, 20:29
  4. I want to fit 19" Alloys, will they fit.
    By spandexx in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th February 2006, 16:40
  5. Will these alloys fit my A6?
    By RyanA6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 17th January 2005, 22:11
