Sky InsuranceAH Fabrications
    Oct 2011
    Newcastle Upon Tyne
    57
    Resetting Service light/indicator?? How?
    Hi guys
    Ive only had my car a couple of months,i bought it from a Jag dealer and they serviced it for me as part of the deal, however the service indicator has been counting down and eventually reached zero today and annoyingly will now beep on every start up.
    Is there anyway that i can reset this?
    Cheers Jonny
    Fossie
    Rhubarb Triangle
    3,961
    Take it to a VAG specialist and get them to do it. Basically it depends on which service regime (fixed interval or longlife) you are on and how old the car is. VCDS will reset the counter but the garage you bought it from should have done it in the first place !
    Your service book should tell you what sort of service was carried out.
  1. Resetting Service Indicator.....
    By T0m in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th May 2011, 21:28
  2. resetting service indicator
    By codrock in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st April 2010, 19:48
  3. Resetting Service indicator
    By ma98ard in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th December 2006, 13:39
  4. Resetting Service Indicator
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2005, 14:15
