Volks AutosChris Nott
Results 1 to 7 of 7
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,077
    Talking Guide To Mod Your Audi Locking Nut Covers to Fit Mcgard Locking Bolts or Similar!!
    As a few of you know, I put wheel spacers on my car which required longer hex bolts and longer locking nuts.
    The hex bolt covers fit over no problem but the round locking nut covers were too big for the Mcgard Lock Nuts and simple just fell off..
    Here is my guide for how I modded mine for a perfect grip and fit.
    You will need SIX round lock nuts in total, Superglue and that double sided sticky pad stuff used to fix number plates on, also a pair or strong scissors, a small hand saw and a pair of long nose pliers.
    Cut the hex pattern of the top using the small hand saw.
    Leaves you with the hex pattern whuch you can throw away and also a plastic ring which you keep.
    Next you make a split in the ring.
    Then you cut in half.
    Leaves you with two strips, (enough for two covers to be mod)
    Now get one strip and wrap it tight around the Mcgard bolt and mark with a pen.
    Now with long nose pliers holding in place in line with were your pen mark is, use superglue on the over lapping part, then compress together and wait to dry.
    Test over the Mcgard and it should now be a tight grip.
    Cut the double sided pad into two small strips.
    Now stick the two strips on either side of the inside of the round cover nut intended to use. I stuck it near the opening.
    Now get the inner ring made and put it inside, using a bit of force so it sticks to the sticky pad. You will find it a bit fidly to get in, but it does go in, giving a nice tight and secure fit.
    It should now look like this.
    Now test on your Mcgard bolt, and it should not come off. It should be quite a firm and tight grip.
    Repeat this for the other three covers, and then you have job done!!
    I have read that people have just used blutak to hold in place, but by doing that, the fit is not as secure and everytime you take the cover off, you have to mess around putting the tak in place again.
    The beauty of this mod, is that you can take it on and off as you please, just like a normal cover!!
    Guys, I know that this is the not the best mod in the world, but I thought that this would help overs who have had a similar problem. I am also pretty sure this will work on other brand locking nuts provided the diameter is smaller than the actual cover.
    Cheers all.
    Danny
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    warren_S3's Avatar
    Oct 2007
    6,190
    Proper decent re-usable solution, and a great guide; spot on Danny.
    Appreciate you sharing it.
    Audi S3 Panther Black [2011] Build Thread
    Mods: Revo Stg2, Blueflame TBE, Eibach Pro springs, R8 oil cap
    On order: Audi S5 3.0V6T Coupe Black Edition, Phantom Black [Due 26 May 2014]
    Planned Mods: Revo Stg1+ with DSG map, Revo CAI, custom exhaust, H&R Trax spacers, EM Tuning LED interior lights, R8 oil cap, Porsche coolant & brake fluid cap
    mikex709's Avatar
    Jun 2010
    114
    Nice guide Danny, kept it up. We'll meet up soon buddy.
    Nov 2004
    Tonbridge, Kent
    912
    Nice one Danny. I will sort mine out now as well
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,077
    Quote Originally Posted by mikex709 View Post
    Most definitely Mikey.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,077
    Quote Originally Posted by W8 Performance View Post
    Nice one Rob, let us know how you get on mate.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,077
    Quote Originally Posted by warren_cox View Post
    Many thanks Warren, hope this simple but yet effective mod helps others out.
    Searched high and low on google but with no joy, so maybe this mod is a first?
  1. Need HELP with Locking nut!!!!!
    By Stepho in forum General Chat
    Last Post: 18th August 2010, 16:45
  2. McGard 41mm locking wheel bolts 28025
    By OllieH in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2010, 11:33
  3. ARGH - Audi Locking Wheel Nut
    By jb0o in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th August 2009, 01:32
  4. McGard Locking Wheel Bolts
    By I'mRonBurgundy? in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th September 2008, 11:18
  5. Mcgard locking wheel bolts
    By Serberus in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th July 2007, 20:22
