HVAC Unit Display Dim/Bright
G
_G_
Can live with it I suppose but for the first time today since I had the car new from 2007... the dual climate control display went bright...
It stayed bright like it used to when brand new... I guess I never noticed how dim it had gotten over the years.
After a few minutes it was dim.
Then bright again.
Temperature was 5 degrees. Never noticed the brightness being effected by hot/cold weather.
Any ideas... loose solder? Connection or new hvac display?
Check the headlight switch interior dimmer dial, see if this makes any differences by moving back & forth.
