Sky InsuranceAH Fabrications
Results 1 to 7 of 7
    Jun 2010
    65
    Intermittent Tail Light
    My tail light keeps going off, other bulbs ok. I can get the bulb back on if I take it out and put it back in but sometime by the time I've screwed the cluster back in it's off again when I test it! I've tried a new bulb but no luck.
    Any ideas? What's the part called which all the bulbs plug in to called? I've got a multimeter but obviously I can put one terminal on where the bulb touches, but where do I put the other one?
    Thanks for any help I appreciate it.
    The Engineer's Avatar
    Apr 2011
    Mid / Northwest
    329
    Mine used to do this, i did a little investigation and found water to be getting in as my tail light was a little loose.
    once slotted in properly everything is fine.
    Jun 2010
    65
    hmmm it has a little water inside I must admit. On the rubber rings around the 2 pegs has split, do you think that's how the water gets in? It's definitely seated correctly though.
    Apr 2011
    Mid / Northwest
    329
    It may need drying out. Maybe worth removing it and put it in somewhere warm overnight.
    Jun 2010
    65
    I'll give it a go, cheers
    Jun 2010
    65
    If I wiggle the bulb it goes on and off, same with a new bulb.
    Would my best bet be replacing the whole bulb holder? I'v tried cleaning the contact with sand paper already.
    Sep 2010
    Lincoln and Halifax
    143
    I get this so often it's unreal. Normally drivers side break light bulb but occasionally the normal bulb. Annoying... Will check for moisture in the cluster etc.
    A3 TDI 140 - REVO Software, Cupra R Splitter, Lamin-X Yellow Fogs, Spax 45mm Springs, 18x8 RS4 Reps In Gloss Black, De-Wipered At Rear
  1. A4 Cab Tail Light Question
    By Adam TTR in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th February 2011, 21:42
  2. Tail light problems - help needed
    By A3.Lee in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th October 2010, 21:24
  3. Rear Tail Light problem HELP!
    By S3mad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st October 2010, 08:29
  4. Euro Tail Light Help
    By BDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th February 2010, 12:17
  5. Facelift tail light fitting
    By Oranoco in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th May 2009, 20:55
Tags for this Thread
