Volks AutosSky Insurance
Results 1 to 13 of 13
    Jan 2012
    rear brake caliper bolts - HELP!
    Hi,
    Could anyone tell me what size the head of the hex bolts on the rear calipers are and where I can get the tool to remove them from, just getting ready to fit new rear pads, and want to make sure i've got all the right tools ready, already bought the rewind tool.
    Thanks!
    Adam.'s Avatar
    Meow.
    Mar 2011
    Glasgow
    652
    You don't need to remove the hex bolts iirc.
    2 spanners will do.
    Jan 2012
    Thanks Adam, do I just untighten the bolts on the caliper rather than removing the caliper then?
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    The caliper splits from the carrier to allow you to change the pads.
    Only need to remove the carrier if you were changing the discs also.
    I believe they are 7mm cap screws? Please correct me if I'm wrong.
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    Jan 2012
    Thanks, couldn't find a "how to" on this anywhere, giving it a go tommorrow
    Roady's Avatar
    Nov 2010
    Hereford
    42
    How did you get on cunningfox?
    I've changed my (old) focus', but not changed my Audi A3's yet... The focus was easy, but getting the right size hex bolt was an utter nightmare!
    Darkside Warrior! (Diesel) & former Focus (FFOC) nut
    Current ride: Audi A3 '06 2.0TDI Quattro
    Apr 2010
    21
    Link below for a MkV golf, which I belevie is the same. at least thats what I followied when doing mine
    DIY: Changing brake pads & rotors | Volkswagen Rabbit/GTI/Jetta/GLI MkV DIY & FAQ
    Apr 2010
    21
    Link below on how to do this on the MkV golf. This is what I followed on mine, and to remover the carrier, its the 14mm triple square you'll need
    DIY: Changing brake pads & rotors | Volkswagen Rabbit/GTI/Jetta/GLI MkV DIY & FAQ#
    dex140's Avatar
    Dec 2009
    190
    You will need a caliper windback tool! Other than that its a piece of P!
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    The rear bolts which hold on the carriers are spline sockets not torx's, do NOT use a torx's otherwise you will round them off.
    Plus they are a git to get on a 2wd A3 and even more a of a git to get to on a Quattro!
    I know as i did a Quattro a month ago and a 2wd sportback last weekend!
    Jan 2011
    105
    Quote Originally Posted by RobinA3 View Post
    This isn't really what I wanted to read, as I have mine to do very soon. I did them on a skoda octavia yesterday, and assumed that they would be almost identical to do. Does anyone have any tips to make getting onto the carrier bolts any easier? And my air gun isn't man enough to get the bolts un-done, so I had to use a breaker bar (not easy when working on the floor!).
    2007 8P S-line 140 TDI BKD Sportback. Milltek De-cat, Cat-back, AMD remap, 312mm Brake conversion, Bose, Alcantra Leather, BT, Dark Headlining, Piano black trim, courtesy light pack.
    Oct 2010
    69
    If you're only doing the pads you only need two spanners and a wind back tool. (IIRC). To just do the pads you don't need to remove the carriers so no breaker bar needed.
    Jan 2011
    105
    Thanks Bodders, but I need the discs doind too!
  1. Rear Brake caliper
    By gav in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2011, 20:27
  2. rear brake caliper
    By dieselfitter251 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th August 2009, 23:38
  3. best place to get a rear brake caliper
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2009, 13:47
  4. rear brake caliper
    By pafranky in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2009, 20:13
  5. S6 Rear brake caliper..help!
    By crispin in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd August 2007, 13:06
