Volks AutosAH Fabrications
Results 1 to 7 of 7
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    Rough idle cure :)???
    Yep - I did a write up about this some 6-9 months ago !
    I'll see if I can find it !
    EDIT - here it is :-
    This is for version 908 :-
    Ignition on - engine off
    Select Engine controller 01
    Select Measuring blocks 08
    Select 'Go' in Group 1
    Start Engine ( you may be able to start engine earlier but I don't )
    Hit 'Turbo' button at top of page
    Select 'Done'
    Select Adaptation - 10
    Change channel to 06 and hit 'Read'
    First figure shows actual rpm
    Stored value shows rpm as originally set ( mine is 840 )
    New value will show same figure
    Use up/down buttons to change revs and when happy press 'Test' to see if ok
    If ok then hit 'Save' and close otherwise fiddle around with revs and test until happy.
    "If like me you are bothered with rough idle/tickover use Mike Fosters guide(above) to turn revs DOWN,
    yes that's right turn them down for a while I have been turning mine up (thanks Ewan)with little improvement, to my surprise I have just
    turned rpm down to 800 rpm with INSTANT improvement ,
    It has only been 10 mins so I guess time will tell"
    May 2009
    West Yorkshire
    1,609
    Did doing this cure it permanently?
    Audi A3 2.0L TDI S-Line Sportback
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    Quote Originally Posted by AidenUK View Post
    done it a month ago and although it hasnt taken it away completely i can hardly notice it now
    May 2009
    West Yorkshire
    1,609
    Did the engine miss or just judder? You can hear mine miss when it's doing the juddering thing!
    I'm actually desperado to try and get this fixed!
    Jan 2012
    14
    i have the same sort of problem its fine when driving but when am sat at the lights it misses now an then.
    May 2009
    West Yorkshire
    1,609
    Quote Originally Posted by _scotty_ View Post
    Mike Foster lowered the idle on mine down to 800 RPM and it's not spluttered, juddered or missed ones today since. You watch i'll of jinxed it and it will start playing up tomorrow!
    Apr 2012
    Hi Guys,
    I just got an 54 plate A3 with a rough idle when stood at the lights. It disappears when the air con is on high and the load on engine rises.
    Anyone near Leeds with the laptop and software mentioned above that would be able to help in return for a few quid?
    Si
  1. Rough idle really rough
    By audiv6quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th March 2011, 15:33
  2. New flywheel to cure idle wobble
    By Rigla in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th February 2011, 20:18
  3. rough idle
    By simon1303 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th April 2010, 16:24
  4. Rough Idle
    By melman in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2007, 19:29
  5. Rough Idle
    By ad3crk in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th October 2006, 09:52
