Volks AutosChris Nott
Results 1 to 25 of 25
Like Tree1Likes
  • 1 Post By jb0o
Thread: CH/LH LIGHTING MOD NOT WORKING-2007 SPORTBACK
    Jun 2011
    Roslin
    105
    Guys,
    Recently tried to get the above mod done but couldn't get it to work. Wiring mod and coding done as per the normal script but no luck. Has anyone had the same problem with a Sportback or is it just me?
    Comments appreciated...
    Cheers,
    S
    kkp0897's Avatar
    Sep 2009
    Essex (Boy)
    553
    What's CH/LH Mod?
    You can take the boy out of Essex but not Essex out of the boy...
    Jun 2011
    Roslin
    105
    It's the come home/leave home mod when you remote open/close the car the fog and headlights come on for a pre- determined time. There is a guide on ASN but I couldn't find the link. I printed it off tho some time ago...
    kkp0897's Avatar
    Sep 2009
    Essex (Boy)
    553
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,571
    Its the Earthing of Pin12 plug-E of The CE Board. More of a fix than a retrofit but seems to work fine on 3dr but not so on 5doors...
    Audi A3 2.0TFSI S Line SE DSG
    JMB Retrofits - North East Retrofit Company
    Jun 2011
    Roslin
    105
    Cheers kkp.....
    Thats the script I had printed off..
    S
    26,761
    Did you leave the wire in place or just literally do touch.
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,571
    I did the install when fitting his LED Tail Lights.
    I did the CH wiring as I have done many before. Repair wire into PIN12 of Plug E in CBE. Earth the other end and code. Usually when I've coded and it doesn't work I need to remove the earth and re-earth as it acts as a switch, but rather than this I always unplug and plug in the E plug again which has always worked.
    I have done around 5 CH/LH fixes on 3dr A3's and out of the 2 Sportbacks that I've attempted the mod on, they both wouldn't work. I can only assume it to me a Sportback issue... though I've no idea what could possibly affect it.
    26,761
    Maybe an idea to compare 3/5dr coding & see what differs & try changing to suit 3dr & try enabling, I cant really do, as I have the full works already & atm havnt got time to disconnect it all & test on our sb.
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,571
    Cheers Nige. I've got coding from my 3-door and an auto-scan from Scott's SB so I'll do some comparing.
    Its just as if PIN12 has a whole different function on a SB -- but that would seem pointless.
    SWILKO likes this.
    26,761
    Nah, pin 12 does same on 5dr.
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,571
    Thought it would have... strange...
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    I had it working perfectly on my SB, same procedure as per the guide posted above.
    make sure that the ch/lh activation by sensor is not ticked. i think it looks something like ch 0=user personalisation / 1=via light sensor
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,074
    Definitely works and codes the same on SB as I have done a couple with success. As you said Johnny, just unplugged and plugged again as the earth point acts as a switch.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Jun 2011
    Roslin
    105
    Thanks for all the replies gents. Looks like I'll have to do without but it's not the end of the world, the rear LED's are more than makng up for it!
    Cheers,
    S
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    Try connecting the wire and then disconnecting it. I had a problem with mine when the wire was permanently connected, but found connecting it for a second to 'enable' the function did the trick. Check your coding first though
    For Sale -
    A3 rear wiper motor and arm
    A3 air vents
    56plate A3 S-Line full speaker system including amp
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,852
    Ive done my sportback.......same procedure!
    Full leather/19"wheels/cruise/
    Helifella's Avatar
    Flying low level
    Nov 2011
    North Yorkshire
    330
    Follow Helifella On Twitter
    Quote Originally Posted by moag View Post
    Did you connect the wire with the ignition on to switch it? just trying to troubleshoot for newer cars.
    Regards
    HeliFella
    I.A.M. Member http://www.iam.org.uk/about-us/
    '61 spec, A3 Sportback S-Line Black Edition in Ibis White, EM Tuning upgraded LED extended interior XL lightpack,
    Duxback Glass Treatment, Diamond Vision front fog lights, shortened number plates,
    gloss black rear rings & black edition S-line wing badges. Blackvue DR550GW 2 channel in-car camera with Smart Power battery protection.
    Jun 2011
    Roslin
    105
    Had Jb0o on this one for me. Tried most of the ideas but still couldn't get it workin. Next thing would be to hook up with him again but like long distance relationships, it's not easy!!!!
    LOL!
    just love this smiley, no other reason for putting it in....
    S
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,571
    Sorry haven't been on to check this thread!
    Very strange as a lot of SB's seem to be accepting it...
    The coding was purely the Bit 5 & 7, I didn't check the personalisation button as this, I assume, is if the button is installed.
    I wired everything up fine as I have done 5 times before and the first time it didn't work I unplugged and plugged back in again to no avail. I then resorted to changing the wire and the earthing location, again to no avail
    jsosic's Avatar
    Mar 2011
    Zagreb, Croatia, Croatia
    167
    I have another problem, I activated Coming Home lights, without wire, and it works OK, but when I deactivate it, it stays on! I thought it would be possible to somehow set up coming home for fogs and LEDs only (MY09) and not the Xenons... I don't want Xenons to fire up with coming home, it will burn them much faster, it isn't healthy for them as far as I know?
    Now I've turned the code back to original and coming home keeps turning on, how is this possible?
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    there is no problem with the headlights coming on, it will not damage the xenons.
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
    jsosic's Avatar
    Mar 2011
    167
    are you certain?! I mean it is like 5 or 6 fire ups per day more than usual... That increases wear for sure, I mean you have balasts etc...
    And how to turn coming home back off? I switched bit 5 and bit 7 off in byte 00 and it doesn't help coming home still powers on the lights
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    yes that is fine, as long as you are not sitting there with the switch in your hand and flicking the switch like a child i think the xenons would be fine. i had the ch/lh mod on my car for a while before i installed the auto lights pack and now it runs as per oem and lights up at night.
    in fact i used to sometimes just unlock the car just to see the light as i think its cool being able to switch the lights on without being in the car
    turning it back off is the part that puzzles me. as all you did was code them to be on so surely by recoding them it should go off... maybe try the coding again and see if you turn on and off again what happens. also check your DIS for any tick boxes on the exterior light part
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
    jsosic's Avatar
    Mar 2011
    167
    Quote Originally Posted by itwasntme187 View Post
    I figured this out!!! Take a look:
    Altering time for ch/lh lights
    Also, I think it isn't the most healthy thing for the Xenons to be firing like a madman 5 times a day, isn't that why the DRL was invented so that Xenons would be spared of the excessive load?
  1. mod that went wrong on my sportback! Grr
    By drnutta in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th October 2011, 21:05
  2. engine cover for s3 sportback after the air intake mod?
    By kinson in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th February 2011, 20:22
  3. 2007 Sportback bonnet
    By b19ctr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th August 2010, 08:42
  4. intrior lighting not working.. dash not working.. please help
    By patrick swayze in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th September 2007, 12:16
  5. Lighting up the dark - improving road safety with intelligent lighting
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th June 2005, 21:40
