Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By BlueSpark
Thread: Problems with Xenons
    L80EWY's Avatar
    Sep 2009
    331
    Well I'm in the middle of doing an 8P1 to 8P2 facelift and I bought a set of single xenon headlights off Ebay.
    I haggled and got them a lot cheaper than they were advertised so the seller sold me them out of eBay (probably a stupid idea for me)
    The problem is I've got the lights and on one headlight the bits inside move if I tilt the headlight forward or backwards as if it's not attached inside, has anyone ever experiences anything like this? I'm thinking it could be something to do with the adjustment bit not being attached or something?
    Also I stupidly out of curiosity took out the bulb on that headlight and I can not for the life of me get it back in. Im probably being stupid but I can't figure out how the mechanism works.. Do you put the red and black box on then turn the circle bit? Or turn both them together I'm stuck!
    Thanks for any help
    Fossie
    Rhubarb Triangle
    3,961
    Have you read all the threads about aftermarket Xenons ?
    Do you know they will blow your wiper motor (every time )
    Have you read the sticky ?
    Do you know they are illegal ?
    Do you know that you need auto-levellers and headlamp washers to pass the MOT ?
    L80EWY's Avatar
    Sep 2009
    331
    They are OEM XENON HEADLIGHTS.
    Who said anything about not having washers or self levers?
    Does the sticky answer any of mt questions. No
    So you didn't have to give me a bell end reply thanks
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by L80EWY View Post
    Bit touchy eh ?!! No need for the insulting comment fella !
    Have you got self-levellers and washers or is that in your plan ?
    Ok - they are OEM and won't blow the wipers - sorry, my mistake.
    However they will still be illegal and will not pass the MOT without the other items.
    Hope you get them sorted (legally )!
    BlueSpark's Avatar
    Aug 2010
    South London
    386
    L80ewy when you say the bits inside move do you mean the projector lens? The igniter is a bit fiddly but easier to put on when headlights are off the car. Your right its just a case of making the three bits that stick out at bottom of igniter slot perfectly into the black bulb holder ring and turn clockwise (i think) to lock into place.
    jsh likes this.
    Ron
    Audi A3 8P2 2.0Tfsi S-Line Special Edition Bluefin
    3dr Mauritius Blue || Full Leather|| BOSE || MFSW || Auto Lights/Wipers || Auto Dim Rearview Mirror || Heated Mirrors
    Mods: S3 Aluminium Pedals || S3 Vents || 2010 RNSE || OEM Bluetooth || Dension Gateway 100 || MY09 Rear Lights || Single Xenon Headlights
    L80EWY's Avatar
    Sep 2009
    331
    Just didn't like the fact you jumped to conclusions an was like you were having a go for me not reading the sticky ha sorry. I will be having a friend MOT it, probably not what some people would recommend or be happy with but they headlights will be aligned so should be fine.
    L80EWY's Avatar
    Sep 2009
    331
    Quote Originally Posted by BlueSpark View Post
    Yeah the lenses etc are all moving but just from the bottom.. And I'm sure the leveller attaches to the bottom of the lenses ?
    I've got the headlights off and I still can't manage it haha, cheers though
    Fossie
    Rhubarb Triangle
    3,961
    Ok mate - maybe my post was a bit abrasive and for that I am sorry.
    However, your last comment is a bit of a worry as that defeats the object of having the necessary safeguards in place to eliminate, or at least mitigate, the serious and more and more prevalent problem of being blinded by illegal xenons.
    I think your friend will need to consider seriously the implications of what he is prepared to do for you, assuming of course you do not have the necessary additional items fitted.
    Once again, I hope you get it sorted, legally.
    L80EWY's Avatar
    Sep 2009
    331
    Does anyone know if you can remove the whole inside of the headlight if you take the lens off the front of the headlight?
    26,734
    I suspect the levelling bar has come loose or plastics broken, you can remove the front by heating it up around the edges & then have a look inside, if you dont feel confident then, get someone who does, could send to me to look at.
    I actually have a set of bixenons for sale shortly aswell.
    c_w
    1,047
    You can't really see anything more with the front lense off unless you're going to dismantle it. If as above you remove the front lense you should be able to dismantly the light units by unscrewing the top 2 torx screws as it sounds like the 3rd screw that is normally holding the level motor to the light unit isn't connected. There is a slight chance the ball has come out of the socket??
    Unless the xenon are different to the halogen, the level motor is the only contact point at the "bottom" of the light units, there are two ball joints at the top on either side held on by the torx screws.
    26,734
    That was my point mate, remove the lense so you can gain access to the internals.
    Farhan's Avatar
    Feb 2011
    West London
    1,228
    when i bought my bixenons the levelling bar had come loose it was fairly easy to put it back on however. If you take a photo from inside the cap it may be of help.
    Send it to Nige he'll fix it
    2008 A3 1.8TFSI 3 Door S Line - Lava Grey - Bose - Bluetooth - S Line Full Black Leather - Aux - Comfort Pack - Coming Home Lights - Storage Pack - Cruise Control - Ambient Interior Light - Footwell Lights - Audi IPhone 4 Cradle - Leather Armrest - BE Rear - MY09 Rear Lights - S3 Pedals - S3 Vents - BBS RS866 - Bi Xenons - Bluefin Stage 1 - K&N 57S Intake - Rev D Valve - Powerflex Dogbone Insert & Gear Box Mount
    c_w
    1,047
    Yes I know, just clarifying that removing the front lense won't give you any more idea of what's going on unless you are def going to strip it which is from the back anyway, as all fixings are seen with both back caps removed.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    i have a feeling you have got the same issue that Farhan had with his where it had fallen off a clip and free to move.
    Farhan eventually fixed it by fiddling with it but im sure he can help you out more.
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
    Farhan's Avatar
    Feb 2011
    West London
    1,228
    Yer, its pretty easy once you remove the headlight assembley. I was arguing with it kept adjusting it via the small white plastic circle to move the level up and down so it would slot in. Genius that i am then realised all i had to do was push the metal hook towards the right and slot it back in! LOL :-) CLEVER BOY I AM
    L80EWY's Avatar
    Sep 2009
    331
    Thanks for the info people, will be taking the headlight apart then. Ive just bought these headlights, or I would have maybe considered your bi-xenons NHN
    L80EWY's Avatar
    Sep 2009
    331
    When replacing a bulb... Do you lock this circle bit in first then the igniter onto the back of that ??
    BlueSpark's Avatar
    Aug 2010
    South London
    386
    Yes
    Ron
    L80EWY's Avatar
    Sep 2009
    331
    Sorted it, cheers. Took some doing !
  1. Fitting Bi-Xenons to 8P1 with Factory fit Xenons? Possible? How!?
    By Joe90k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2013, 21:35
  2. Pre face lift s3 xenons to facelift s3 xenons..
    By donjon in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st October 2011, 17:06
  3. swapping 8p2 bi-xenons to 8p3 bi- xenons
    By a3_sline_tdi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th August 2011, 17:25
  4. How can you tell the difference by looking at xenons ? bi xenons ?
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th February 2010, 14:04
  5. Looking to get Xenons (possibly BI XENONS)
    By nagges187 in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th October 2003, 20:37
