EM TuningJMB Retrofits
    Sep 2009
    Engine management light on
    Hi Had my engine management light come on last night. Gave it a scan with a mates vag com and it came back with two error codes.
    18530
    04803
    Anyone know what this could be ? Car seems to be driving normal.
    thanks
    Fossie
    Rhubarb Triangle
    3,969
    Are you sure your mate was using the official VCDS (previously vagcom) ?
    Neither of those fault codes are listed in the Ross-Tech website fault code pages.
    Here is the link to the fault code pages :- Category:Fault Codes - Ross-Tech Wiki
    Sep 2009
    No it wasn't the official one.
    I took it too Audi today to get it's MOT done. They diagnosed the car to have 2 problems.
    Which will cost the following to get sorted:
    Bank1 Lamda Probe £221.03
    Solenoid valve and charcoal canister £262.12
    Not too sure what to do as I would like to change the car soon and £500ish is alot to spend on a car that I want to change.
    Fossie
    Rhubarb Triangle
    3,969
    See if you can find a specialist independent VAG garage near to you. They'll probably do the job for half the price !
    Worth a try anyway 'cos dealerships are a complete rip-off labour wise.
  1. Coil Light Flashing & Engine Management Light
    By vik007 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd December 2012, 19:43
  2. abs and esp light on with engine management light
    By madsad1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2010, 18:22
  3. engine management light and traction control light always on
    By martin9k in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th April 2010, 13:31
  4. ESP light then Engine Management light
    By V6Pete in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th March 2010, 08:50
  5. Engine management light and ESP light on
    By AndyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2005, 14:30
