- Joined
- Mar 12, 2009
- Messages
- 7,567
- Reaction score
- 817
- Points
- 113
- Location
- London and surrounding areas
Hi guys
For anyone that has already done this...
I am going to be installing the new facelift door modules tomorrow and have been looking into the pins that need to be moved from my current 20 & 32 pin plugs to match that of the facelift modules.
i have dug up some info from another thread here on the forum but its getting a little confusing as the list is showing some pins that dont exist on my current wiring.
below is the list that i have put side by side to show the differences in the pins. the RED pins are the ones that i am really unsure about. the others are colour coded to show which pin goes where:
This one is even more confusing!
Does anyone know exactly which pins i need to move over? is there a definitive list or guide out there for which pins go where? the ones that i have coloured can be moved but what of those in red that i cannot identify?
any help is appriciated!
Connectors, door control unit, driver side -J386 (year 04-08) | Connectors, door control unit, driver side -J386 (from year '08) |
20-pin connector (supply, lock) | 20-pin connector (supply, lock) |
1 - Mirror dip input signal 1 (EC mirror +) | 1 - Mirror dip input signal 1 (EC mirror +) |
2 - CL motor SAFE | 2 - CL motor SAFE |
3 - CL feedback locked/safe | 3 - CL feedback locked/safe |
4 - CL outside door handle | 4 - Not used |
5- Vacant | 5 - Not used |
6- Vacant | 6 - CL terminal 31 |
7 - CL terminal 31 | 7 - CL door contact switch |
8 - CAN - High | 8 - CAN - High |
9 - CAN - Low | 9 - CAN - Low |
10 - Mirror dip input signal 2 (EC mirror -) | 10 - Mirror dip input signal 2 (EC mirror -) |
11 - CL motor SAFE/lock | 11 - CL SAFE LED |
12 - CL terminal 30 | 12 - CL motor SAFE/lock |
13 - CL keyswitch close/open | 13 - CL motor unlock |
14- Vacant | 14 - Not used |
15 - CL door contact switch | 15 - LIN |
16 - CL motor unlock | 16 - CL keyswitch open/close |
17- Vacant | 17 - Not used |
18 - WL enable, terminal 87 (vacant) | 18 - CL terminal 30 |
19 - WL terminal 31 | 19 - WL terminal 31 |
20 - WL terminal 30 | 20 - WL terminal 30 |
32-pin connector (to door trim) (year 04-08) | 32-pin connector (to door trim) (from year '08) |
1 - BE - Exit/warning lamp | 1 - Status LED - Interior locking button |
2 - BE - Terminal 31 (2) (AWL) | 2 - Not used |
3 - BF - Window lifter button rear right | 3 - Status LED - Child lock button |
4 - BE - Terminal 31 (1) (AWL) | 4 - Status LED button for interior monitoring (deactivate interior monitoring) |
5 - CL SAFE LED | 5 - Status LED button for alarm system off (deactivate tilt sensor) |
6 - BE - Terminal 58b (1) | 6 - BF - Mirror adjustment L/R |
7 - BF - Interior locking button (LOCK/UNLOCK) | 7 - BF - Window lifter button rear right, driver |
8 - BF - Window lifter button front right (local) | 8 - BF - Mirror adjustment X/Y |
9- Vacant | 9 - Not used |
10 - Memory button + emergency off button (only with seat memory fitted) | 10 - Alarm system Off button (tilt sensor inactive) |
11 - Memory position buttons (only with seat memory fitted) | 11 - Not used |
12 - BF - Tailgate remote release button (only in 5-door, USA) | 12 - Not used |
13 - Alarm system Off button (tilt sensor inactive) | 13 - BF - Button for tank lid unlock |
14 - BE - Interior door handle illumination | 14 - BF - Child lock button |
15- Vacant | 15 - BF - Window lifter button front right, driver |
16 - Status LED button for interior monitoring (deactivate interior monitoring) | 16 - Not used |
17 - Status LED button for alarm system off (deactivate tilt sensor) | 17 - BE - Interior door handle illumination |
18 - CL - Inside door handle (not implemented) | 18 - BE - Door exit/warning lamp |
19 - BF - Mirror adjustment L/R | 19 - BE - terminal 31 |
20 - BF - Mirror adjustment X/Y | 20 - Not used |
21 - BF - Window lifter button rear right (local) | 21 - BF - terminal 31 |
22 - BE - Terminal 58b (2) (mirror adjuster switch) | 22 - Not used |
23 - BE - Terminal 58b (3) (mirror/stowage illumination) | 23 - BF - Window lifter button rear left, driver |
24 - BF - Window lifter button front left (local) | 24 - BE - terminal 58b |
25- Vacant | 25 - BE - terminal 58b |
26 - BF - Child lock | 26 - BE - Switch/stowage compartment illumination |
27 - Memory supply terminal 30 | 27 - Button for interior monitoring |
28 - BF - Button for tank lid unlock | 28 - Not used |
29 - BF - Mirror heating | 29 - Not used |
30 - Button for interior monitoring | 30 - BF - Tailgate remote release button (only in 5-door, USA) |
31 - LED - Interior locking button (LOCK) | 31 - BF - Window lifter button front left, driver |
32 - LED - Child lock button | 32 - BF - Interior locking button (LOCK/UNLOCK) |
