JMB RetrofitsEM Tuning
    Feb 2011
    299
    Fitted new seats now airbag light on.
    Fitted my new seats yesterday, from a mk2 tt and the wiring plugs were different to those on my a3 so as expected the airbag light came on.
    If I changed the plugs from my original seats onto the new ones cure this? Or can it be turned off via diagnostics? The seats are lovely and far outweigh the inconvenience of the airbag light being on but I am aware of the new mot laws coming into pal e meaning this would be a fail.
    Any help greatly appreciated!
    Ta
    Wanted - a pillar covers, leather interior, rear bumper, standard head lining
    Cardiff, United Kingdom
    390
    Might not be the same as mine but I remember when I changed my seats I had a warning light come on, I was advised on here to take the car out for a spin round the block which did the trick, light went off after a few hundred meters, yards, whatever.
    Feb 2011
    299
    Oksweet cheers, will try changing the plugs over and see if that works.
    Many thanks
    27,031
    If they're the same pins on the end then yeah, but you need to also make sure the 3 pins are also round the right way as the previous so pin 1 to pin 1 etc
    Feb 2011
    299
    Yep will do.
    Many thanks.
  1. S3 Seats in A3 - Airbag Light - Solved at last
    By FactionOne in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2014, 13:46
  2. Yellow airbag connector under seat causing airbag light to come on
    By pj123 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th December 2012, 18:46
  3. Removing old seat with detonated airbag. How to? Also Airbag light?
    By Stanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th March 2011, 18:30
  4. s3 seats in a3 airbag problem
    By ste_1210 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2008, 12:08
  5. AIRBAG WIRE's S3 SEATS
    By lakhan in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th February 2004, 13:48
