JMB RetrofitsVolks Autos
    Jul 2011
    65
    Oil pressure sensor? Help.
    Hi peeps,
    Having a slight problem with my car.
    When its running for a bit the oil lights comes on and flashes. When i check the oil level in the car there is plenty. Someone had suggested to me that it could be a faulty oil presure switch.
    Could anyone shed any more light onto this, or if someone has exp the same sort of problem in the past?
    Thanks in advance.
    Jag
    27,033
    Check what the actual warning symbolises, vcds should show a log, then you can attack the correct sensor if its this.
  1. oil pressure sensor location
    By Shawny-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2011, 10:20
  2. Oil Pressure Sensor
    By darreng1983 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2011, 15:32
  3. 1.8T Oil Pressure Sensor
    Last Post: 26th March 2011, 12:15
  4. Oil Light, Pressure, sensor???
    By ben_turbo1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2010, 12:45
  5. oil pressure sensor
    By litfoo in forum Classic Audi Forum
    Last Post: 16th June 2005, 23:27
