Monster MotorsportChris Nott
Results 1 to 12 of 12
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    Car wouldn't start this morning
    Hi folks this morning my car wouldn't start properly it started first then died most prob the imobiliser cut in , but as I turned he ignition back off to try again the parking light (hand brake light) and emissions lights stayed on with the ignition off , try again just turned over left it a min tryed again took a while but it started ok , anyone got any ideas of what it could be not plugged the car into my works handheld scanner yet
    Fran
    off the road boohoo anyone got a gearbox for me lol!!
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    Scanned the car with our hand held scanner this came Up
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,148
    This is what it says on Ross-tech's (VCDS) website:
    17978/P1570/005488 - Engine Start Blocked by Immobilizer
    Possible Symptoms
    • Engine starting but stalling immediately
    Possible Causes
    • Key(s) not matched
    • Instrument Cluster not matched
    • Engine Control Unit (ECU) not matched
    • Engine Control Unit (ECU) Power Supply faulty
    Possible Solutions
    • Check for Fault Codes in Immobilizer itself (part of Instrument Cluster in many cars, but separate Immobilizer Control Module in some)
    • Check Immobilizer Measuring Values (usually in Instrument Cluster OR Immobilizer Control Module)
    • Match Key(s)/Instrument Cluster/Engine Control Unit (ECU)
    • Check Engine Control Unit (ECU) Power Supply (Relay)
    Special Notes
    • In case of Engine Starting Issues please make sure that you are really experience an Immobilizer related Problem! Even if the Immobilizer engages, the Engine will still start fine but cut out after 2-3 Seconds. If you are NOT experiencing this behavior (e.g. Engine doesn't start at all) your Problem is very likely NOT Immobilizer related.
    • May be stored in Combination with 01176 - Key: Signal too Low in Immobilizer Control Module.
    • If no other immobilizer related fault codes are stored and the immobilizer related meas. blocks are fine except Engine Start not allowed, in rare occasions it helps to try cold-booting the car. Remove both battery cables from the battery. Short the battery cables together (away from the battery) for about 15 seconds. Reconnect the battery. (Example)
    So looking at those possibilities I would guess its:
    The ECU relay would be a good place to start. Think it's under the bonnet in that plastic box.
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    Cheers ads will have to take a look see , Rhys thinks it may be my battery that's pooped or on its way out
    Sheikh's Avatar
    Aug 2011
    Surrey
    658
    I had this on my 2.0 TDi one morning mate, turned out to just be a random event. Although at the time it kind of sh*t me up lol
    55' BMW 330Cd M Sport
    The ones that have been left behind:
    • 2004 VW Golf R32
    • 2004 Audi A3 2.0 TDi Sport
    • 2000 BMW 318i M Sport
    Private plate for sale: Y 7RYY
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    I too ****e myself mate lol I just hope it's the battery as its the original one I'm sure
    warren_S3's Avatar
    Oct 2007
    6,132
    Hoping its the battery. Relatively easy fix, though not cheap. GSF to the rescue?
    Audi S3 Panther Black [2011] Build Thread
    Mods: Revo Stg2, Blueflame TBE, Eibach Pro springs, R8 oil cap
    On order: Audi S5 3.0V6T Coupe Black Edition, Phantom Black [Due 26 May 2014]
    Planned Mods: Revo Stg1+ with DSG map, Revo CAI, custom exhaust, H&R Trax spacers, EM Tuning LED interior lights, R8 oil cap, Porsche coolant & brake fluid cap
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    Quote Originally Posted by warren_cox View Post
    Yeah I hope to god its just a battery problem , lol yeah or euro car parts one of the two if not TPS to the rescue but that will be a last resort lol
    26,762
    If the lights stayed on with ignition of, then I'd be leaning towards the ignition barrel given the symptoms as a duff battery wont leave dash running when turned of.
    But, if battery then grab yourself a Varta Silver Ultra Dynamic, much better battery.
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    i thought it was weird never seen it before (i work for a car sales place ) the emissions light and hand brake light stayed on when the ignition was off very strange got me really worried if there is something seriously wrong with my car gonna chuck a battery on soon just got to pay the finance this week first lol always happens when something has to be payed , good batteries are they nige ??
    26,762
    Its gotta be a dodgy ignition barrel if the lights stayed on, battery wont do that as thinking logically the barrel is an on/off switch to the cluster, the battery supplies the power but doesnt activate the systems without the switches turned on, given ignition was turned of, means the switch was of as such.
    Yeap, great battery.
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    Well the car has done 98k now so could be worn out I suppose first time it's done it
    Hmm may have to invest in one
  1. S3 slow to start in the morning
    By beanoir in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th September 2011, 20:27
  2. first start of the morning
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd August 2011, 09:51
  3. car struggled to start this morning
    By pjw in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th November 2010, 12:43
  4. Car won't start in morning!!
    By JayA4Turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th October 2003, 23:25
