Badger5EM Tuning
    Jan 2012
    Redditch
    Bad Electrics on a 2.0TDI 3 door sport
    Ok Guy's and Girl's
    Couple of questions, the drivers door sometimes turns the dash on when you open the door, but more often than not it is not doing a thing and then the door will lock itself after a couple of minutes with the keys in the car. The rear wiper has stopped working, the washer still works and when you press the stalk forward you can hear the relay cklicking in and out, are the motors prone to failure? you can buy them on Ebay for 95quid, is that about the right price. The headlight adjustment motors will only work if you "Slap" the headlights really hard on both sides and then they are very stuuttery if you know what i mean.
    The rest of the car is fine, just feel the electrics are not that strong for what i feel is a quality car. The Car is an 04 plate with leather and travel pack and cruise, and now has 105,000 on the clock have no real intention of getting rid of it as its immaculate, Bought it when it was 6 months old and i still enjoy it my only regret is not holding out for a DSG Darren
    27,080
    Lock/microswitch could be clogged in the door hence why its acting up, common tbh on older cars, may need either wd40 or replacement lock.
    Wiper motor in rear is common issue, so remove & check 1st water is coming through pipe which needs the rear boot trims removed, if is then remove wiper parts & I suspect its corroded as mine has recently, hence replacing motor & the wiper nipple head as such.
    Which headlights do you have, halogen or xenon, do you have a headlight manual levelling dial with settings 1-3 inside the car on headlight switch?
  1. Door electrics
    By B5NUT in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th June 2011, 08:18
  2. Door Electrics
    By Ronniebiggs in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd January 2010, 13:13
  3. Drivers Door Electrics
    By Mothman in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th April 2009, 05:43
  4. DRIVER'S DOOR ELECTRICS HELP
    By jr001 in forum General Technical / How To
    Last Post: 22nd December 2008, 10:41
  5. Offside rear door - electrics ?
    By Markm49 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th February 2008, 22:23
