AH FabricationsVolks Autos
Results 1 to 7 of 7
    Dec 2007
    35
    Are their variations in cruise control stalk?
    Hello All
    I am still trying to get my cruise control to work
    I took the wiper motor out to double check the aditional wire I had to run, and have also checked it for continuity... All is well with that.
    I was wondering if there were different stalks for different years? My car is a 2004 model and I did notice that the indicator stalk on the cruise module had slightly different markings (different arrow design to show the full beam possition etc) than the stalk I removed. I put this down to a revision, but I am wondering if the part is incorrect?
    Any thoughts? Sadly I don't have the part number to hand, so if there are variations I will have to remove the cowling to check.
    Vag com has shows the clutch switch is working.
    Many thanks.
    Jan 2012
    i think it could have been changed around the year 06 fit the new type a3. if you could get ur hands on the parts number then i could check in my work to see exactly mate
    Dec 2007
    35
    Thanks mate!
    Im working tomorrow, but will take it apart to have a look on Monday
    Khufu's Avatar
    West coast of Scotland
    5,693
    just to make sure, you have used VCDS to code the engine module to know it has cruise control? I retro fitted cruise to my 53 plate A3. I had to upgrade the slip ring & steering control module together with adding the extra wire but the stalk I got wasn't any specific revison.
    Dec 2007
    35
    Thanks. Yep I have coded the engine and the steering ecu. My steering controller should support CC so I don't think it's that...
    26,777
    Should support, doesnt sound very convincing, what is your steering cu version, assumption is the mother of all........................
    You only need a compatible steering cu, no need to change slip ring unless you want mfsw/paddles
    If the wires in pin 13 of steering cu connector, then 9 times out of 10 its wired all way through anyway, but always worth a check if everything else IS in order & doesnt work.
    Dec 2007
    35
    I say "should" as it is listed as doing so on the rosstech website. The part number is 1K0 953 549 A.
    The pin 13 wire wasn't present when I initially fitted the cruise, so I was double checking my own work really.
    Thanks for any thoughts.
  1. A4 B7 s-line cruise control stalk and cowl
    By sub7 in forum Parts Requests
    Last Post: 9th August 2011, 12:04
  2. Cruise control stalk price please
    By Relaxitscool in forum Parts Requests
    Last Post: 8th January 2010, 18:38
  3. C5 Indicator stalk with Cruise control
    By simonwjones in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 6th July 2007, 16:15
  4. A4 Cruise control stalk
    By almistry in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st July 2005, 21:22
