Sky InsuranceVolks Autos
Page 1 of 3 123 LastLast
Results 1 to 40 of 88
Like Tree3Likes
Thread: Imminent RNS-E Install...
    XXXCorps's Avatar
    Nov 2011
    193
    Hi all,
    I've bought an August 2011 RNS-E which I'm tentatively going to attempt to fit to my May 2011 A3 Black Edition this Saturday. My car has Bose, Bluetooth phone prep, glovebox USB and rear parking sensors. To say I'm nervous about this retrofit is an understatement so any input from you guys would be greatly appreciated as I suspect I will be buying the services of someone to get my car reprogrammed at some point! I live in Baxenden, BB5 2xx area in Lancashire so would love any suggestions of any relevant VCDS coders out there that live/work locally...
    Thanks,
    Peter
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,538
    Hi peter if your unsure about fitting it get a member to fit and code it in for you ,, i always do...
    XXXCorps and dobbysline like this.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,370
    Nigel, user NHN may be just the guy your looking for.
    27,038
    It will need some wiring changes & coding to make it work fully, so as advised, someone who 1st knows what they're doing & 2nd has the tools to complete the job for you.
    Give me a shout if my services are of use.
    XXXCorps's Avatar
    Nov 2011
    193
    Where are you based Nigel?
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Nige is in Kent but travels
    XXXCorps's Avatar
    Nov 2011
    193
    Quote Originally Posted by paddy View Post
    Thanks for that Paddy; I'm in Lancashire so quite a few miles away from there unfortunately...
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    Jonny (username jb0o) lives in Cleveland, and he is a well known Audi retrofitter with his own business. He'll be a bit closer for you. PM him.
    2012 RNSe Navigation Discs with unit software update. PM me.
    Suzuki GSX-R 750 K5
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    wesley's Avatar
    Giac Extreme+!! Lovin it
    Feb 2007
    Manchester
    323
    I'm in Manchester and can install and code if needed.
    07 Suzuka Grey S3, Giac Extreme plus map, Autotech HPFP, VF Engineering CAI, 18" black rims,factory tints,fbmfsw,Mk 2 RNS-E,CH-LH lights.puddle lights,Bose,Shark fin, Lamin x lights & Fogs.Full TBE miltek, 09 White DIS,Buckets,LED conversion,TPMS.
    XXXCorps's Avatar
    Nov 2011
    193
    Quote Originally Posted by wesley View Post
    Wesley you may just be the lifesaver I need; could you possibly PM your number etc; I'll do the same now...
    XXXCorps's Avatar
    Nov 2011
    193
    Just want to say thanks for comments and messages guys on this issue; Wesley is kindly doing the install and coding for me tomorrow so crisis averted!! :-)
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,538
    Top bloke endless coffees
    Sep 2010
    392
    Quote Originally Posted by XXXCorps View Post
    Hi all,
    Thanks,
    Peter
    I fitted a RNSE (September 2011) to my car just over a week ago (to my 2011 a3 s line).
    At first I found it quite simple to remove the radio - Fittings off the cables can be abit fiddly though! After installing the unit, I marked my chrome trim very slightly above the hazard button (so be careful not to rest the RNSE on there as it will damage it).
    My car seems to be working fine without the coding, it has instructions on the DIS and the MFSW works like it use to. However the AUX is no longer working.. which was a downfall but i've decided not to have it coded.
    One mistake I did make though was the GPS cable goes at the top of the RNSE unit at the back (blue slot).. I was putting it in the radio one :/ Oh and after you position yourself on the map.. it may tend to go off course for 5 - 10 miles, then it calibrates itself and works perfectly.
    With you having bose though, I'm sure I read something about a pin having to be changed?!
    Hope this helps
    Picked up on the 30th May!
    2013 '13' Plate - Audi TT 1.8 TFSI S Line Roadster | Ibis White | Xenon Headlights with LED DRL | Half Leather/Suede with Silver Stitching | Brushed Aluminium Trim
    Gone but won't be forgotten! 2011 '11' Plate - Audi A3 1.4 TFSI S Line | Ibis White | Privacy Glass | iPod Dock | Xenon Headlights with LED DRL | Half Leather with Silver Stitching | Brushed Aluminium Trim | S3 Pedals
    Cruiser89's Avatar
    Advanced In Car Technologies
    Bournemouth, Dorset
    1,424
    Follow Cruiser89 On Twitter Add Cruiser89 on Facebook Visit Cruiser89's Youtube Channel Visit Cruiser89's Instagram Channel
    I posted up a small guide on my thread... Hope it helps.
    Quote Originally Posted by Cruiser89 View Post
    Ok guys...
    So I got a bit bored at home today so decided to install my MK2 RNSe and its so good compared to my MK1 (This is for sale now, PM if interested)
    Here are a few pics of the install:
    Old Concert out and loom/aerial unplugged
    My old GPS aerial about to go in
    If you look closely, there is a hole in the top of the dash where I mounted the GPS. There is a little ledge up and slightly to the left.
    GPS installed and the excess wire is cable-tied and "cloth taped" to the original loom to make it look as OEM as possible.
    As I have BOSE I need to swap the BOSE pin in the blue block.
    The BOSE pin was originally in pin 5 and needs to be relocated to pin 7. Unfortunately one of the AUX pin outs is already in pin 7, so I removed that and will relocate it to its correct pin outs when I install AMI
    You can now see that the brown wire which is BOSE has now been relocated
    Here is the brand spanking new RNSE MK2
    Here is the unit all plugged back in
    All that was needed was to install Navigation (37) in Can Gateway (19), activate telephone on the RNSe and change the splash screen to S3 (Because it looks coooooool - ha)
    Now I just gotta fill this up with some music
    XXXCorps's Avatar
    Nov 2011
    193
    Thanks again for the posts there; they're incredibly helpful and informative... :-)
    XXXCorps's Avatar
    Nov 2011
    193
    Just wanna say again a very very big thanks to Wesley for fitting and coding my RNS-E; you were great fella and looking forward to hooking up again sometime...
    Kelza likes this.
    2013 Audi TT 2.0 TFSI S Line Black Edition. Misano Red.
    Amplified Black Package. Comfort Package. Technology Package. Heated Seats.
    http://s1308.photobucket.com/user/xxxcorps/media/photo1_zps1e5c9a3f.jpg.html
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,538
    Leds next lol ...
    Aug 2012
    Im wanting to do exactly the same - can you point me in the right direction? Im from County Durham so looking for a northerner who knows the ways...
    Im tempted to try it myself but dont want to muck up my brand new A3 Black Edition...
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,370
    Quote Originally Posted by Dmrqwq View Post
    Pm nigel, user NHN. He is top guy and he travels as well. x
    Fossie
    Rhubarb Triangle
    3,969
    jb0o is in Hartlepool ( see post #8 ) and does this sort of thing for a living. He will soon sort you out. Send him a PM.
    downtothebone's Avatar
    Mar 2012
    Wimbledon
    202
    I went from a BNS5.0 Navigation head unit to the latest RNS-E model - do i need to recode and wire swap? I have BOSE - all appears to be working
    27,038
    Well yes depending on what year & if any adapters used, wire swap maybe needed, coding for sure will need to be checked & changed accordingly.
    Mar 2012
    Wimbledon
    202
    Right - old unit was made in 2010 new one in 2012 and car is a MY11. I simply plugged all the various connections into the right places. I did have to turn down the bass setting on the new unit - it was just too overpowering.
    27,038
    Still needs coding checking tbh, does it have a dsp menu under sound
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    NHN dont know if N8 got hold of you, as i meet up with him yesterday but I have two error (see below) and i also noticed that the Bose cable was still in pin 5. do you think my errors will go if i can relocate the Bose wire. i take it the grey wire is the aux? the car is MY11/12 if that helps
    2 Faults Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 53
    Mileage: 2112 km
    Time Indication: 0
    Date: 2012.06.06
    Time: 13:08:02
    02005 - Coding Pin
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 53
    Mileage: 2112 km
    Time Indication: 0
    Date: 2012.06.06
    Time: 13:08:02
    27,038
    Yes if you have Bose then move wire which then requires codes cleared & will lose the coding pin error, the antenna error is because you have retro'd rns in a post late 06 car & needs antenna fix for it aswell, which I can do when you have the audiopilot sorted out & light pack, if still needed that is
  28. #27
    Mar 2012
    Wimbledon
    202
    Yup DSP->GALA
    VCDS should be with me next week I'm just not sure about the wire swapping bit ...
  29. #28
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    yep still looking for the door handle LED's, audiopilot and footwell lights. What you think the causing the antenna error?
    when you going to N8's next or up manchester way?
    will move the Bose wire, when i can get it out, i though they just clipped out of the housing, any tips?
  30. #29
    27,038
    Yeap so needs coding.
    VCDS next week, did I sell it to you, if so, sorry if I dont recognise your username
  31. #30
    27,038
    Quote Originally Posted by bloblob2 View Post
    The post late 06 cars use different antenna system, which needs upgrading to make radio 100% compatible with rns-e which I do often for rns upgrades.
    I'll be up there soonish mate, just working/family away atm, but when back I'll be up there straight away.
    Yeah remove 12 pin housing from quad, then with small screwdriver, oush the little locating clip down & pull the 009 wire out & push into the correct pin, taking note if 7 is connected, then its the aux in that needs to be removed anyway which is wired different on rns-e & you should remove all 3 auxin wires not leave plugged in.
  32. #31
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    All 3, which ones are those? grey, green and ?
    i'll wait till you you come up north lad, would rather get it right
    Can you pm me a price, so that i can sort my funds out. hoping to get this sorted or the rsne is going, as the sound can go quiet sh*te
  33. #32
    27,038
    Yes I'll PM this afternoon if thats ok as gotta go out now
  34. #33
    Mar 2012
    Wimbledon
    202
    Yup Garry - paid on Friday ...
  35. #34
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    that would be great lad, enjoy the day
  36. #35
    27,038
    Quote Originally Posted by downtothebone View Post
    Aha I thought so, sorry mate so many usernames, cant remember them all
  37. #36
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    don't forget me NHN fella
  38. #37
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    Hello NHN, pm me lad
  39. #38
    Aug 2012
    Im still 50/50 on getting the RNS considering the number of reported thefts and the difficulty in finding one at a reasonable price which isnt nicked (one ebay seller told me that a "couple of scrapes on the casing are to be expected when the unit is withdrawn" - needless to say I havent purcahsed from him!). If I can find one at a reasonable price and even someone to fit it in the north east then I might well go ahead!
  40. #39
    Fossie
    Rhubarb Triangle
    3,969
    jb0o (forum member) is your man - based in Sunderland I think. Send him a PM.
  41. #40
    Aug 2012
    When I work out how to I shall! Does he supply units?
  1. RNS-E install
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2013, 12:05
  2. RNS-E Install Done....
    By cliveywolves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th January 2007, 12:49
  3. RNS-E Install Help Please.....
    Last Post: 9th January 2007, 21:58
  4. RNS-D Install - What do I need?
    By mykaloon in forum In-Car Entertainment
    Last Post: 25th August 2006, 17:06
  5. RNS-E install
    By beerglass in forum In-Car Entertainment
    Last Post: 22nd June 2006, 12:22
