Monster MotorsportChris Nott
Page 3 of 3 FirstFirst 123
Results 81 to 88 of 88
Like Tree3Likes
Thread: Imminent RNS-E Install...
  1. #81
    27,014
    No need to extend wires as per stated, peel coroplast back & route to new 32pin connector, its plenty long enough
  3. #82
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    no nothing else needed other than the 32 pin connector & coding NHN?
    lesson learned is get to know people who know what they're on about
  4. #83
    Jun 2010
    East Manchester In the Hills !
    672
    Quote Originally Posted by bloblob2 View Post
    Correct
  5. #84
    downtothebone's Avatar
    Mar 2012
    Wimbledon
    201
    Having swapped my BNS (Navigation) 5.0 unit for an RNS-E MK II (Glossy surround) and not done any coding or wire swapping (I thought it was plug and play ...) I've just run a VAGCOM diagnostics and got the following fault codes ...
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
    Component: RNS-E PU EU H06 0200
    Revision: 0000012S Serial number: AUZBZ7MD206483
    Coding: 0225725
    Shop #: WSC 00295 211 124470
    VCID: 3461228A57D224B8F5D
    4 Faults Found:
    00878 - Connection to Speaker Front Left
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 42
    00879 - Connection to Speaker Front Right
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 42
    01303 - Telephone Transceiver (R36)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 196
    Mileage: 16862 km
    Time Indication: 0
    Date: 2012.07.20
    Time: 16:58:15
    03157 - Functionality limited due to Communications Disruption
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 196
    Mileage: 16862 km
    Time Indication: 0
    Date: 2012.07.20
    Time: 16:58:04
    Freeze Frame:
    Bin. Bits: 00000100 00000000
    Bin. Bits: 00000000 00000000
    Bin. Bits: 10000000 00000000
    Same faults under the radio section. What do I need to do??
  6. #85
    27,014
    Check your coding for systems fitted to the car.
  7. #86
    K13 ASJ's Avatar
    Aug 2011
    Buckie (north east scotland)
    176
    the three aux wires i have are, yellow green and grey, can anyone tell ne which is left/right/ground?
  8. #87
    Aug 2012
    Cotswolds
    57
    Sorry to hi jack but i can't PM yet, NHN have you received my email ref an RNS-E and CC ? thanks.
    Simon
  9. #88
    K13 ASJ's Avatar
    Aug 2011
    176
    i figured it out, aux now working woohoo!
  1. RNS-E install
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2013, 12:05
  2. RNS-E Install Done....
    By cliveywolves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th January 2007, 12:49
  3. RNS-E Install Help Please.....
    Last Post: 9th January 2007, 21:58
  4. RNS-D Install - What do I need?
    By mykaloon in forum In-Car Entertainment
    Last Post: 25th August 2006, 17:06
  5. RNS-E install
    By beerglass in forum In-Car Entertainment
    Last Post: 22nd June 2006, 12:22
