EM TuningMonster Motorsport
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 88
Like Tree3Likes
Thread: Imminent RNS-E Install...
  1. #41
    26,776
    As per my PM, I supply/fit mate, I'll reply to your latest shortly, just gotta backlog to go through.
  3. #42
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    ok fella, just trying to get things sorted thats all
  4. #43
    Banned
    Aug 2012
    Cotswolds
    44
    PM'd you NHN.
    Simon
  5. #44
    May 2012
    Carlisle
    234
    Just so I know when I eventually get a RSNE when I swap the pins for the Bose where so the aux wires Pi into allowing the aux to work on the RNSE?
  6. #45
    Jul 2012
    71
    Why does the blue pin need moving and what does it actually change? Is it easy to hear the differece?
  7. #46
    26,776
    Aux wires go into 32pin connector on rear of rns, pins 6, 21 & 22 iirc.
  8. #47
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    yep think your spot on NHN, looking at my concert HU and RNSe; Aux R (blue) = Pin 6, Aux L (green) = Pin 22 & Aux Gnd (yellow) = Pin 21
    do you need to code the Aux input back in via vcds?
    all i got to do now is get them out of the housing, tricky things they are!!
  9. #48
    Banned
    Aug 2012
    Cotswolds
    44
    Didn't realise there was a PM qualifying post count, NHN could you email me costs for supply of new RNS-e and fitting to a 2012 BE sportback.
    Many thanks
    Simon
    simon@waxattack.co.uk
  10. #49
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    Think I'll need to buy the 32 Pin AMP Connector to get the AUX wired in. Does anyone have a part number for the connnector and housing that fits into the quad-lock??
  11. #50
    Jun 2010
    East Manchester In the Hills !
    597
    32 pin connector for Aux in
    1J0 972 977 G
    About 3 quid and had to be ordered from Germany on a next day delivery if I recall
  12. #51
    Jun 2010
    597
    I thought yours had all been wired in properly Rob. Still unhappy with it ?
  13. #52
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    yep lad, still having problems
    getting there though, sure the sound will be sweet soon
    how things going with yours? goochy lad
  14. #53
    Aug 2012
    Denmark
    25
    Quote Originally Posted by simonj View Post
    Many thanks
    Simon
    Simonj, I'm total newbie in here, do I understand you right, do we need to be "qualified" to sent a pm to another member in here??? I've sent a pm to NHN, but hasn't got an answer yet, hopefully because he's busy:/
    _____________________________________________
    Kindly
    Jan
  15. #54
    Banned
    Aug 2012
    Cotswolds
    44
    Quote Originally Posted by runnernorth View Post
    I believe so, i also sent a PM to NHN but no reply to date.
    Simon
  16. #55
    Aug 2012
    Denmark
    25
    All right , sounds strange that we have to be "qualified" hmmmmm, but thx for confirming, I hope you ( and I ) will get an answer, or we will " be seen" in this thread........
    Kindly
    Jan
  17. #56
    K13 ASJ's Avatar
    Aug 2011
    Buckie (north east scotland)
    176
    i have ordered the 32pin connector today, does anyone have pics of the exact process regarding the aux wires? is it a simple pull em out of the blue bit its in now and into the 32pin connector, then that fits in the quadlock?
  18. #57
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    hopefully someone will but pin locations are taken of my RSNe
  19. #58
    26,776
    I havnt forgotten anyone, just having some net issues atm, so please dont worry I will reply to everyone asap.
  20. #59
    K13 ASJ's Avatar
    Aug 2011
    176
    I know where the wires go now, what about how to get them there? i.e how do they connect to the 32pin connector? and how does the 32pin connector connect to the rns-e?
    Mayb it will be clearer when i get the connector,
    Sorry if its stupid questions..
  21. #60
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    have you looked at the quad-lock? look at the photo's earlier in this thread
  22. #61
    26,776
    32 pin connector uses the same pins as the aux uses on the quadlock, just remove these by removing the 12 pin connector from quadlock with a thin screwdriver to push down on the locking tab, then the wires slide out, then reinsert into the 32 pin numbered holes, then plug into the rear of rns above the antenna connectors, trust me its so obvious with connector & rns in hand
  23. #62
    K13 ASJ's Avatar
    Aug 2011
    176
    Thanks nigel, alot clearer now. I'm sure it will be easy enough when i have all the parts, i'm probz worrying for nothing.
  24. #63
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    does the Aux need to be re-coded in NHN?
  25. #64
    26,776
    Yes auxin must be coded into rns.
  26. #65
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    ok lad. need to get the 32 pin connector. the rsne was destined for the bin, hopefully things on the sound front will start to improve
  27. #66
    26,776
    Nah dont bin, let me get my hands on it 1st lol.
  28. #67
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
  29. #68
    K13 ASJ's Avatar
    Aug 2011
    176
    on the back of the original quadlock there is 2 blocks one green, one blue, they both have the same coloured wires in.
    Is it the wires from the blue block only that is the aux wires?
    and the green block stays in place on the quadlock?
    pic below to show what i mean..
  30. #69
    26,776
    Ok, all 3 wires go into the same connector, so look at top of your old radio on the label & it will be very obvious mate
  31. #70
    K13 ASJ's Avatar
    Aug 2011
    176
    ahh ok, got it now. thanks..
    Any advise on where to put the nav antenna?
    and the bluetooth module?
  32. #71
    26,776
    BT under passenger seat, cutout the foam thats there now, bond the module to this with some bubble wrap on top for good measure & tight fit & refit foam in place again using the locating lugs/holes in foam so cant move, gps antenna fit with 3-4 layered double sided foam tape to the right of the passenger air vent.
  33. #72
    K13 ASJ's Avatar
    Aug 2011
    176
    Thanks, i will update later to say how i have got on..
  34. #73
    K13 ASJ's Avatar
    Aug 2011
    176
    ok i have it all wired up etc..
    The bluetooth symbol is not showing on the rnse screen and my phone is not picking it up..
    does it just need coding?
  35. #74
    26,776
    You need to code rns, bt for comfort control aswell.
  36. #75
    K13 ASJ's Avatar
    Aug 2011
    176
    Thanks, i knew it would need coding, just thought it may still be showing when i tried to pick it up on my phone.
    Hopefully all is good and it will be working fine when coded.
  37. #76
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    Bose cable now moved to Pin 7 and 32 pin connector on order, already sounding alot better
    i'm liking my RNSE again
    any advise on extending the 3 AUX cables, so that i can relocate them into the new connector?
  38. #77
    Jun 2010
    597
    Quote Originally Posted by K13 ASJ View Post
    Check this out
    http://audiretrofit.quinlivan.net/rnseauxin
  39. #78
    Jun 2010
    597
    Quote Originally Posted by bloblob2 View Post
    Just cut the tape around the wires. They will reach then
  40. #79
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    which way did you do it goochy lad?
  41. #80
    Jun 2010
    597
    Rob I just pulled the wires out of the quad lock. I identified them from the wiring diagram on the Symphony 2. I then slotted them into the 32 pin connector which I got from Audi whilst looking at the wiring diagram on the RNS then had it coded. Works a treat.
    I still have the BOSE wire disconnected as it made no difference to the sound. I now think it sounds great. I do think you have to wait a few thousand miles for the whole stereo to "bed in" and loosen the speakers up a bit.
    Very happy with mine now. Volume still an issue but hey I can live with that especially as it only when on low
  1. RNS-E install
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2013, 12:05
  2. RNS-E Install Done....
    By cliveywolves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th January 2007, 12:49
  3. RNS-E Install Help Please.....
    Last Post: 9th January 2007, 21:58
  4. RNS-D Install - What do I need?
    By mykaloon in forum In-Car Entertainment
    Last Post: 25th August 2006, 17:06
  5. RNS-E install
    By beerglass in forum In-Car Entertainment
    Last Post: 22nd June 2006, 12:22
