Badger5AH Fabrications
    Jan 2012
    Angry help radio signal on concert radio
    need help again soz i can't get a good reception in my audi a3 its got a standard concert set in it i thinks its the concert 2 sometimes i do get reception any ideas audi 2005 plate
    colicabcadam
    try looking in the boot on top of the amp (left side panel usually), i believe all the aerials hook up in that area
    Jan 2012
    ok thanks mate i'll try that i didnt know they had an amp
    Fossie
    Rhubarb Triangle
    3,969
    The rear window heater acts as an aerial. If any of the wires in the glass have broken then that could also cause the problem.
    If that is the case it needs a new rear screen I'm afraid.
    colicabcadam
    or a metal ink pen ? that's what my old man told me anyways, you can join them back up !!!
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by colicabcadam View Post
    Might be worth a try but I didn't have much success, presumably because the impedance would be unbalanced.
  1. Cab radio signal...
    By Louis Cronin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st September 2012, 10:16
  2. Replies: 8
    Last Post: 16th June 2010, 21:41
  3. Replies: 4
    Last Post: 16th June 2010, 12:30
  4. RADIO CODE for A3 S S LINE 55 plate with CONCERT radio???
    By niffty in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd April 2010, 19:44
  5. S3 Radio - no signal!
    By Spacecowboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2008, 12:16
