RNS-E II / playlists problem on SD
klik
Europe
My 2008 S3 was equipped with the 1st generation RNS-E, which I replaced with a brand new 2010 MK II unit.
Each of my SD cards had about 20 folders with corresponding playlists on the root.
On my old unit, once a playlist finished, the next one started in perfect order as it should.
Unfortunately, that is not the case with the new unit. Once a playlist is finished, the cue changes to the 1st folder (alphabetical)
and songs play (again alphabetically).
Reformatted the cards and saved new playlists (with Tag & Rename), tried various SD cards including Sandisk Extreme but same problem.
The 1st playlist that I manually select, plays the songs in the proper order but after the end, same problem.
The dealer replaced the unit with a brand new one manufactured in July 2011 (hardware 06 & software 0200) but same problem.
Anyone with a MK II RNS-E with the same problem?
thnx & Happy New Year
klik
9
835
NHN
