Results 1 to 1 of 1
    Feb 2008
    Europe
    231
    RNS-E II / playlists problem on SD
    My 2008 S3 was equipped with the 1st generation RNS-E, which I replaced with a brand new 2010 MK II unit.
    Each of my SD cards had about 20 folders with corresponding playlists on the root.
    On my old unit, once a playlist finished, the next one started in perfect order as it should.
    Unfortunately, that is not the case with the new unit. Once a playlist is finished, the cue changes to the 1st folder (alphabetical)
    and songs play (again alphabetically).
    Reformatted the cards and saved new playlists (with Tag & Rename), tried various SD cards including Sandisk Extreme but same problem.
    The 1st playlist that I manually select, plays the songs in the proper order but after the end, same problem.
    The dealer replaced the unit with a brand new one manufactured in July 2011 (hardware 06 & software 0200) but same problem.
    Anyone with a MK II RNS-E with the same problem?
    thnx & Happy New Year
    klik
  1. MP3 playlists with RNS-E
    By john_cook in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th April 2010, 20:19
  2. ITunes playlists to SD cards
    By Keef in forum In-Car Entertainment
    Last Post: 25th June 2008, 13:28
  3. Do MP3 playlists come up in the MMI?
    By Juniper44 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th January 2008, 18:39
  4. RNS-E playlists
    By Vertigo1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd November 2006, 18:16
  5. MP3 playlists on Nav+
    By Dandle in forum In-Car Entertainment
    Last Post: 14th March 2006, 21:36
