    jon1984's Avatar
    Jan 2012
    Lincoln
    Right Dipped Headlight Bulb Change
    I have a 'Right Dipped Headlight' warning on the dash, the bulb has gone. Ive tried to change it but the bulb seems difficult to get out if i could get two hands on it but as I can only just about get one hand to it Im struggling.
    Is there a knack to getting the bulb out?
    2004 A3 2.0TDI
    Mar 2011
    Cleveland
    862
    Hi, get hold of the plastic bulbholder and press firmly down, the bulb and holder will tilt and you can pull it out. Change the bulb and reverse the procedure, making sure the lug is square to the top. Put the bottom of the holder into the hole and click the top in. If it doesn't seat properly, it'll be because the lug's out of line. You can watch what you're doing through the lamp lens!
  1. headlight bulb change
    By marktdisport in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd December 2011, 10:31
  2. `left dipped headlight` but bulb and fuse are okay
    By synthdood in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th November 2010, 13:01
  3. Dipped Beam Bulb Change Help
    By Wai-Fan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th July 2010, 19:17
  4. Headlight Bulb Change on A4 2006 (B7)
    By comc in forum General Technical / How To
    Last Post: 6th February 2010, 21:15
  5. 2006 A6 Headlight bulb change!
    By walshyuk in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th January 2010, 17:27
