Sky InsuranceAH Fabrications
Results 1 to 9 of 9
Thread: dpf light on
    jessie123's Avatar
    Sep 2011
    s.wales
    79
    dpf light on
    jessie123: dpf light on<br>hi all happy new year to you all <br>my dpf light came on again but there is no dpf pipe any more &amp; remapped about 6 weeks ago now 203 bph and very good tourqe. put back on vag com no errors found.its a a3 8p 2.0 quattro any help welcome
    347
    347's Avatar
    Sep 2006
    249
    even though the dpf has been removed the pressure sensors are still retained in the delete pipe , it could be one of these failed , these normally give a fault code though .
    phone up or take it back to the remappers is probsbly your best bet
    Jun 2011
    Wellingborough
    1,156
    As said above, if the pressure sensor is caked then you will need to change that for the light to go off your DIS.
    upside is your not in limp mode..
    Aug 2008
    Manchester
    130
    Quote Originally Posted by t8ups View Post
    Yet! I had the DPF light and emissions light on despite the DPF delete, turned out to be a dodgy wire on the pressure sensor.
    jessie123's Avatar
    Sep 2011
    s.wales
    79
    dodgy wire
    is that the exauhast pressure sensor on the back of the bulkhead if so i changed that 6 weeks ago before the dpf delete and remap
    jessie123's Avatar
    Sep 2011
    s.wales
    79
    Aug 2008
    Manchester
    130
    From memory yes, there's not much else other than the software that can bring on the light now the dpf is gone.
    jessie123's Avatar
    Sep 2011
    s.wales
    79
    how do i now if i have a dodgy wire . and also there is aflat spot on hard acceleration for a split second
    Jun 2011
    Wellingborough
    1,156
    if you bought the sensor from Audi take it back to them and if its faulty they will change it for free.
    it is the one at the top of the engine bay.
    SLOW REPLIES BETWEEN 22nd - 30th June due to been out the office, please bare with me. Thanks
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
  1. DPF Light Question
    By 3DTDi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th July 2011, 09:44
  2. Idling fun Now DPF light is ON??
    By MOOSH in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2011, 17:01
  3. DPF or not?
    By todgerino in forum Diesel forum
    Last Post: 13th January 2011, 22:01
  4. Replies: 2
    Last Post: 25th November 2010, 16:00
  5. DPF
    By ghouseman in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th January 2010, 22:30
